Paint Two Tone??? - Painting - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 09:11 PM   #1
Paint two tone???
Can you guys give me any tips for getting a nice crisp dividing line when painting my garage two-tone?
I'm planning on using a light grey for the top and a darker blue for the bottom 40" of the walls.
Any tips would be great!!!
I've already got really good masking tape.
mopowers is offline   Reply With Quote
Old 09-24-2009, 09:31 PM   #2
Haste Makes Waste
Do not use regular masking tape as it will pull off the paint. For fresh paint, use 3M Blue Painters Tape for Delicate surfaces. If paint over 30 days use regular 3M Blue Painters Tape. I hear the green frog tape is even better but have not used it. Don't buy off brand painters tape, it doesn't remove well and will pull paint.
It's good to run somethiing solid over the tape such as putty knife or whatever to assure even adhesion and do not stretch the tape.
saggdevil is offline   Reply With Quote
Old 09-24-2009, 11:02 PM   #3
paint
Even when using the blue tape, when you go to pull it off after painting, pull from the area closest to the surface. Don't pull from a foot or two away as you go, keep pulling gently from near where it touches the garage. Otherwise you can still pull the paint off.
Allison1888 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
