Paint Suggestions Needed. - Painting - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 01:59 PM   #1
Paint suggestions needed.
In a previous thread, I was looking for a mesh, which I was able to find. Now, I'm looking to paint it. The type of plastic is polyethylene. I need a paint, rubber, whatever, that won't chip, and will last a while. I use this mesh on my Jeep to keep rocks from hitting the radiator. I don't care about price, but I do care about how long it takes to paint it. A spray paint would be the fastest.
Here is a picture of the product that I'm looking to paint:
Does anyone have any suggestions?
Evyllchyld is offline   Reply With Quote
Old 10-14-2011, 02:53 PM   #2
Evyll, Krylon makes a spray called Fusion which is formulated for plastic. I'm not sure if it would work with pe or due to the flexibility of the mesh, but I can't think of anything else that would. Give it a shot, can't hurt.
Old 10-14-2011, 11:29 PM   #3
I appreciate the suggestion. I went out and bought a can tonight, and it didn't work. I could easily scrape it off with my finger.
So, I'm open to other suggestions.
Old 10-14-2011, 11:53 PM   #4
(the original)
Rewards Points: 756
Cure time is seven days. And yes, it's spec'd for polyethylene.
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
jsheridan (10-15-2011)
Old 10-15-2011, 05:30 AM   #5
Evyll, rather is correct. All of a paint's characteristics are a function of its dry/cure time. A common mistake of many. Let it set for seven days, then give it the evyll eye.
Old 10-15-2011, 10:28 AM   #6
Try using the "DIP" that is used for hand tools such as pliers, channel locks, etc. It comes in a variety of standard colors and it remains flexible.
I've used it on different materials but don't know if it's "PE" specific. Otherwise, ?
BZWAK is offline   Reply With Quote
Old 10-15-2011, 11:55 AM   #7
Msradell's Avatar
Rewards Points: 210
Since the material is already plastic why not just leave it unpainted? If you're worried about how it looks put it behind your regular grill in front of the radiator. It should blend in nicely installed that way you won't have to worry about painting it or repainting at when it becomes chipped!
Msradell is online now   Reply With Quote
Old 10-15-2011, 04:45 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
Advice needed on paint prep... myke232 Painting 25 03-18-2012 08:12 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
