Paint Still Blistering After 5 Redo's - Painting - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 04:57 PM   #1
Paint still blistering after 5 Redo's
Southern Washington coast beach cabin. Southern wall - upper shingles have been painted (Home Depot BEHR exterior satin paint) and blistered. Bottom of wall just fine - just upper portion. I scraped and repainted. Same problem. Restraped, applied Kilz primer and then repainted - same problem. I have let it dry out first since we do get alot of rain. I have even let primer stay overnight and it will bubble. Anyway I have done this fives times to non avail. Rest of house paint is 99 ok except for a couple of small spots on north side with bubbles. Latex over oil base paint ? Moisture and/or direct sunlight - I have let it dry out and have done painting in early morning and late afternoon to eliminate the direct sun light. At end of my rope!!!!!!!!!! Help
shastagoathdr is offline   Reply With Quote
Old 04-02-2011, 05:07 PM   #2
what part of the inside of the house is behind that wall, what room?
The Following User Says Thank You to jsheridan For This Useful Post:
shastagoathdr (04-04-2011)
Old 04-03-2011, 12:01 PM   #3
Attic is behind wall - bedroom below
Old 04-03-2011, 01:12 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
That attic may be heating the wall up too much. Kilz primer is also worthless on an exterior. Prime any bare wood with Zinsser Cover Stain oil and only prime in the morning when the attic is cooler. Same goes for the paint.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Old 04-04-2011, 07:51 AM   #5
Coatings Nerd
Check the moisture level of the wood.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
The Following User Says Thank You to NCpaint1 For This Useful Post:
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint over oil-based = peeling paint! help! ImaDIYnewbie Painting 5 09-20-2010 05:48 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
