Paint Stick - Painting - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 09:26 AM   #1
Rewards Points: 236
paint stick
anyone use them ? i have over the years. the older ones worked great. but this new one i have , WAGNER PAINTMATE, doesn't work as good as the older ones = the paint comes out of the roller only in the center. so more effort and time is needed to get an even and fast coat. but perhaps that is because i am rollin primer, idk yet.
Fix'n it is offline   Reply With Quote
Old 12-24-2012, 09:41 AM   #2
Rewards Points: 13,732
I refuse to use one, takes time to set up and way to much time to clean after using it.
Have you ever once seen a pro painter use one?
ltd (12-24-2012)
Old 12-24-2012, 09:58 AM   #3
Rewards Points: 236
setup is a piece of cake. but yeah, cleanup is a drag. that is why ya only use it for a large space. i leave the parts soak in water between uses.
but i will tell you what. the older ones = FAST !
i also had a power roller. talk about FAST !!! there is a song named LAY IT DOWN. and that is what a power roller does.
Old 12-24-2012, 01:20 PM   #4
Gymschu's Avatar
Rewards Points: 838
We had a guy who painted apartments with a power roller. He bragged about how fast he was. So one day we made a friendly wager. I painted one apt. the old fashioned way, he painted one apt. with his power roller. Long story short, I was done, cleaned up, and out the door and he still had one more room to paint..........I also left with $50 in my pocket. Not saying you can't scoot along pretty fast with 'em, but, any glitches and you're screwed.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (12-24-2012)
Old 12-26-2012, 05:36 AM   #5
In all my years in this business, I've never seen or heard of a pro using a paint stick. I don't think I've ever even discussed it with another pro, but I have had a customer or two ask me why I don't use one.
A rational pro would use every tool possible to decrease production times and increase profits. If they worked and were worth it, they would be in use. They may work for a couple of rooms over a couple of years, but they wouldn't hold up under extensive day to day use and abuse. Also, on many jobs I'm working a couple of rolling pans in different colors, so I'd have to have a couple of paint sticks, and buying the equipment, the specialized covers, and the clean up would probably nil any savings. I can buy a standard roller cover in any paint or hardware store, not so with those. I can't see any reason to even experiment with them.
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (12-26-2012)
Old 12-26-2012, 07:33 AM   #6
Rewards Points: 5,974
The main use I have for my graco power roller is on stucco because it is so rough. In a place where I can't spray the power roller with a large nap cover is a big help.
Old 12-26-2012, 07:48 AM   #7
Rewards Points: 394
Power roller attachments for airless units can be useful for large expanses. They are made much better, and have better capacity to wet the roller than a consumer-grade system. There is some extra cleanup involved, although they can serve a purpose.
Will22 is offline   Reply With Quote
Old 12-26-2012, 08:19 PM   #8
Rewards Points: 236
i would like to see a pro painter going at it. do they have some kind of special tray for the paint ?
Old 12-27-2012, 08:09 AM   #9
cdaniels's Avatar
I am a professional and would never consider using one. I have seen them and I know for a fact that with a little experience any one could out paint it with a roller and tray or roller and a 5 gallon bucket.
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (12-28-2012)
Old 12-27-2012, 09:37 AM   #10
Rewards Points: 394
No, a power roller attachment for an airless unit has a siphon tube connected to the airless sprayer which supplies paint directly to the roller assembly. There is no roller pan/ tray. Most painters , as cdaniels says, use a 5 gallon bucket with a roller grid.
Old 12-27-2012, 10:57 AM   #11
Rewards Points: 236
Originally Posted by Will22 View Post
5 gallon bucket with a roller grid.[/COLOR]
that is the special tool/s i was asking for. i have never seem that. i have always used a tray, and they are slow.
i just tried to find a vid of a pro in action. keywords didn't find any. so if you guys know of such vids, post em up.
Old 12-27-2012, 05:14 PM   #12
cdaniels's Avatar
There is nothing wrong with a tray if you buy a quality tray.The little metal trays are trash,don't use them.Buy yourself a nice deep plastic tray that will hold a lot of paint or use a 5er and a grid.
Old 12-27-2012, 05:24 PM   #13
Rubbin walls since'79
Brushjockey's Avatar
Wait till you hear about an 18"roller and a big boy bucket! Now we are talking rock and roll!
( I personally like a 14" open end and my "special" set up..)
Go to you tube and put in a few search words - you'll find more than you want to know.
Lots in this funny world of painting- you are just sticking your proverbial finger in the paint..!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (12-28-2012)
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
paint wont' stick melonsforyou Painting 4 01-31-2012 09:24 PM
Painting a garage door dfoxworthy Painting 6 06-22-2008 10:51 PM
