Paint Or Stain Pressure-Treated Pine? - Painting - DIY Chatroom Home Improvement Forum
Old 01-25-2008, 10:36 AM   #1
Paint or Stain Pressure-Treated Pine?
I have exterior decking and stairs made from pressure-treated pine.
I've had numerous opinions given as to how to preserve it.
I have been told to let it weather for at least 6 months before doing anything and I've been told that paint will just wear off due to foot traffic.
I've considered an opaque stain. Any suggestions?
Randell Tarin is offline   Reply With Quote
Old 01-25-2008, 02:08 PM   #2
Pro Painter
Rather than try to give all the info here, why don't you do a search for pressure treated lumber. The chemials have changed and there are specific recommendations on how to paint it. You don't necessarily have to wait 6 months. But that depends on the chemicals used and how old it was when you bought it. Was it stored inside stacked? Outside with spacers between it? All these factors help determine what you can do with it and when.
As far as paint or stain, it's your call. However, I've never really liked the look of a semi-transparent (opaque) stain on any treated lumber and it doesn't hold up as long. If you like the look, go for it.
Paint or solid body stain preserves the wood longer because light doesn't pass through. This isn't as big a factor with treated lumber.
joewho is offline   Reply With Quote
Old 01-25-2008, 02:19 PM   #3
I know it lasts without anything on it, I just don't want to go silver with weathering.
If I use paint, do I need to use some sort of epoxy or marine paint?
Old 01-25-2008, 03:19 PM   #4
Pro Painter
You wont' have to be that drastic. Primer and a paint spec'd for decking is standard. Or solid stain. Stain is typically more user friendly.
You might want to do a search on treated lumber first though, or wait until I have time to find you a good link.
thanks for stopping by diychatroom.
Old 01-25-2008, 06:03 PM   #5
Pro Painter
http://extension.missouri.edu/webste...cca-paint.html
Our sister site:
http://www.contractortalk.com/showthread.php?t=3828
http://www.dailypress.com/features/h...r_tab01_layout
Old 01-25-2008, 06:27 PM   #6
Thanks Joewho!
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 08:09 AM
Paint or stain for shingled house? skwpt Painting 6 09-19-2007 06:41 AM
Pressure Treated Decking Broncosfan1983 General DIY Discussions 2 09-13-2007 07:12 PM
Painting pressure treated wood Crackers Building & Construction 1 08-27-2007 10:51 AM
pressure treated or pre-stained?? farrington135 Landscaping & Lawn Care 2 05-03-2007 09:04 AM
