Paint Sprayer Graco Vs Earlex? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 11:02 PM   #16
DIY-Her's Avatar
Rewards Points: 239
thanks so much for your help Canary, Troy and ToolSeeker, that helps end the confusion Airless it is. I guess I could use the smaller tip for stain and/or poly on my floater frames. I wonder how it would work on spraying gallery wrapped canvas prints.
Now to figure out if I need the battery, or electric
DIY-Her is offline   Reply With Quote
Old 09-24-2013, 11:09 PM   #17
DIY-Her's Avatar
Rewards Points: 239
Just thought of another use after the kitchen cabinets, my cement wall and floor in the basement would probably be easier than a roller
Old 09-24-2013, 11:16 PM   #18
DIY-Her's Avatar
Rewards Points: 239
what is the difference between the Graco TrueCoat Pro II Professional Handheld Sprayer 16n673
and
the TrueCoat Plus II Handheld Electric Airless Sprayer 16n659
Old 09-25-2013, 06:51 AM   #19
DIY-Her's Avatar
Rewards Points: 239
ok, think I figured it out, did a lot of searching and reading. I know the difference between the Pro and the Pro II, Pro II is 20V battery and has the option to be able to replace all parts in the future.
Graco TrueCoat Pro II Cordless as much as I can't afford it :-/ I know we have many projects including all our entry doors to the house, and our 2 garage doors along with my kitchen cabinets and thinking it might help paint our 18ft ceiling in our foyer a lot easier as long as things are taped off with plastic.
Plus, there is now a $75 rebate going on from Graco.
Thanks to all for your help in making this stressful decision. I've been working on looking for the paint sprayer and getting ready for another 2 day art festival this weekend, so been a bit stressed.
Old 09-25-2013, 07:11 AM   #20
Rewards Points: 5,974
I would suggest go on you tube and go to Idaho painters he has some really good vids on spraying.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
DIY-Her (09-25-2013), Gymschu (09-25-2013)
Old 09-25-2013, 08:24 AM   #21
DIY-Her's Avatar
Rewards Points: 239
thanks Been on Youtube a lot with looking how to get just my kitchen cabinets done. I'll go check if this was one of the companies I watched. After watching some videos directly from Graco, I know already some of the older videos I watched, the people making the video were doing it wrong in more ways than one.
Old 09-25-2013, 11:43 AM   #22
DIY-Her's Avatar
Rewards Points: 239
I ended up buying it on Ebay $490 then my $75 rebate.
I was able to pay for it with Paypal Bill-pay and have 6 months to pay it down with no interest. Much better than putting it on a credit card
Old 10-09-2013, 08:23 AM   #23
At that price, aren't you afraid tool might broke and you are stuck with no returning or warranty?
I have been debating if getting a graco truecoat II plus on ebay. New, sells for $190 instead $260, but is the saving worth if it brakes...
Flo.G is offline   Reply With Quote
Old 10-09-2013, 09:18 AM   #24
If your buying it new there should be some kind of warranty since the new is sold by dealers in most cases, I think.
I would suggest you go to a couple paint forums , use the search and read the reviews.
Old 10-09-2013, 12:49 PM   #25
Painting Contractor CT
Rewards Points: 77
Post
Paint Sprayer Graco vs Earlex?
They are both descent, comes down to personal preference.
KD PAINTING is offline   Reply With Quote
Old 11-11-2013, 01:42 PM   #26
DIY-Her's Avatar
Rewards Points: 239
my Graco seems to have clogged. I can't even get water to spray through it.
Is there something I need to check? no real phone number to call Graco directly
Old 11-11-2013, 04:21 PM   #27
Jmayspaint's Avatar
Rewards Points: 534
Sometimes the ball gets stuck. A light tap or two in the right place on the pump shaft will loosen it up.
Hard to describe where to tap it, need a pic or model number.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
DIY-Her (11-12-2013)
Old 11-11-2013, 04:43 PM   #28
Also the tip can become clogged try turning the tip 180 degrees so the arrow is pointing toward you then spray this will clear a clogged tip.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 11-12-2013, 10:00 AM   #29
DIY-Her's Avatar
Rewards Points: 239
thank you. I knew about the unclog option, have used it a few times while painting. This time it didn't work.
What I finally did was poured some mineral spirits inside the container and primed the sprayer. Went outside and gave it a few squirts, and eventually it worked itself out. My 4 door frames for my kitchen cabinets came in, the ones I am putting glass in, and I wanted to finish painting them, and my center island. Hopefully I'll have enough done that the kitchen can be more in order for the holidays lol. Still need to replace some of the perimeter cabinets, but thats another project.
The Following User Says Thank You to DIY-Her For This Useful Post:
ToolSeeker (11-12-2013)
Old 08-18-2014, 02:43 PM   #30
This is a great thread!
So much information, research, and thought went into it. I appreciate, as a Graco employee, all the support and information that was shared. This is a truly helpful thread!
I'm happy the TrueCoat Plus II handheld worked for you, and how the benefit of using the right tip makes a world of difference!
Take care!
GracoGuy is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Graco Ultra 1000 Airless Paint sprayer found in workshop ukbrad Painting 2 09-05-2012 08:56 PM
Graco Magnum 261815 ProX7 Hi-Boy Cart Airless Paint Sprayer splinter2 Painting 2 08-08-2012 07:56 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
