Paint Sprayer - Painting - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 12:41 PM   #1
Rewards Points: 256
Paint Sprayer
I'm about to spray an entire basement floor to ceiling.
I think it helps make them not feel like a dungeon.
I've never used a sprayer before.
I'd like to buy rather than rent because I will use it in the future.
Can a gun worth having be had for under $100 bucks? If so which one?
I'd like to spend about $10 on the Harbor Freight one, but I don't have time to gamble buying it, then having it not work.
michaelcherr is offline   Reply With Quote
Old 03-29-2011, 12:55 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
If your going to be spraying out your interior you will want an airless sprayer with a minimum of .25gpm and 3000psi. That is a smaller airless, but will work well for your needs. it will spray oil and latex base products and is usually ment for light use, occasional use. A smaller sprayer will usually only support a tip up to a 015. Which you can still spray latex through, with the exception of thicker latexes such as block fillers. You will want a piston pump and not a diaprham, as piston pumps last longer and spray on the up and down stroke. You can get a small decent airless sprayer for $300-500.
housepaintingny is offline   Reply With Quote
Old 03-31-2011, 10:44 AM   #3
Rewards Points: 256
How do people feel about the Wagner "paint crew" plus.
It boast specs about 10% lower than the above recomendations.
It's a bit more economical, but I'd rather cry once.
I also liked to feature that it has power roller ability.
Does anybody own one?
Old 03-31-2011, 10:53 AM   #4
Rewards Points: 616
I don't know anything about the wagner paint crew. All i do know is that wagner and spraytech are owned by titan. I already gave you my advice for a small diy sprayer that will last
Old 03-31-2011, 10:59 AM   #5
Rewards Points: 256
I appreciate your advise: I am looking for other opinions as well.
Your suggestion involves re-thinking the budget.
I will probably end up buying something nicer than I previously budgeted for, but if I could get by with a cheaper unit and not kick myself for it later that would be great.
Old 03-31-2011, 11:51 AM   #6
Coatings Nerd
Titan, Speeflo, Spraytech, and Amspray all owned by WAGNER Yup.
Worst company on the planet if you ask me. When Wagner bought Titan, guess what. My account got trashed, and im no longer a service center...they also ship me products C.O.D...so my account is gone too. Thats fine, I can buy everything I need for repairs online...for less money...and with free shipping...go figure
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-31-2011, 05:09 PM   #7
Gymschu's Avatar
Rewards Points: 462
THe airless sprayers for less than $300 are junk. On occasion, and, in a pinch, I have purchased a Wagner to do ONE job, maybe some fence panels or some shutters. After that one job, I throw it away........they are a b**** to clean.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Milwaukee Airless/ Fine Finish Paint Sprayer (good or bad?) ehoez Painting 3 10-09-2010 02:56 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
paint sprayer.. mpower22 Tools 1 02-25-2008 05:18 AM
