Paint Sprayed On Concrete - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 09:22 AM   #1
Exclamation
Paint sprayed on concrete
We were painting the outside of our house yesterday and more paint then we were expecting got on the concrete and looks awful, does anyone know how to remove sprayed on paint from concrete? ANY advice would be much appreciated!
Bird1805 is offline   Reply With Quote
Old 08-15-2011, 10:03 AM   #2
a pressure washer will get most of it up. Use the smaller size tip and slowly move across the surface of the cement. You may find that the area will look cleaner now than the rest of the driveway - so be prepared to most likely continuing on to the end.
HDPaintPro is offline   Reply With Quote
The Following User Says Thank You to HDPaintPro For This Useful Post:
m1951mm (08-15-2011)
Old 08-15-2011, 10:07 AM   #3
Probably the easiest and most effective would be pressure washing if you have access to one. Playing around with chemicals will be messy and you risk staining the concrete. If you wash you may have to wash to whole slab to make it uniform. If it's fresh though, you might try some hot water and a stiff bristle brush, no metal, and see if that works. Maybe a little soap too.
Old 08-15-2011, 10:28 AM   #4
Great! Thank you! We do have a pressure washer so that makes me a very happy camper (If it works!) lol, plus it wouldn't hurt pressure washing the entire patio front and back! Again thank you! I'll let you know how it works out.
The Following User Says Thank You to Bird1805 For This Useful Post:
jsheridan (08-15-2011)
Old 08-15-2011, 05:13 PM   #5
Rewards Points: 1,016
Yup, pressure washer - but high power and small tip can etch the concrete, so be aware.
____________
Vince
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
Painting concrete porch with many paint layers underneath normjennifer91 Painting 1 07-13-2009 08:18 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Is it ok to paint concrete floor in winter... dbldee20 Painting 2 02-06-2009 02:06 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
