Paint Smell In Garage - Painting - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 10:04 PM   #1
paint smell in garage
I have some cans of paint in garage. Odd smell coming from garage. Where should I store them. I have a bad headache and a bit naucsious.
suereali is offline   Reply With Quote
Old 03-14-2012, 10:40 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Outside of garage? just a guess.
Are the cans sealed? If so- It is very unlikely them. But if they are leaking, maybe.
Are they latex, oil, shellac, lacquer? What do you have and what shape are they in?
Anotherwords- without some real info- question is worthless.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-15-2012, 06:45 AM   #3
Rewards Points: 101
Yeah I'd say if the smell is that strong then the cans are either not covered tight or they may be leaking. If they are not covered correctly, tap the edges of the cover all the way around with a hammer. If they are leaking dispose of them according to the regulations of the town in which you live. At the very least get them outside.
JMDPainting is offline   Reply With Quote
Old 03-15-2012, 07:59 AM   #4
Even if they are leaking, it would leak a bit, dry, and seal itself. And, I doubt if the little bit of leakage would be enough to give nausea and headache. I would look for another cause. A tip to prevent paint cans from leaking over time is to never allow them sit on concrete for extended periods, as this cause the metal bottom to rust. If you can't put them on a shelf, where I doubt they would leak, set them on some wood or scrap carpet.
Old 03-19-2012, 10:59 AM   #5
Rewards Points: 394
If the paint was exposed to cold weather temperatures, and went through a freeze/thaw cycle or two, it may have spoiled. Generally the odor is like rotten eggs or sulfur. The paint is unusable if this occurs.
Will22 is offline   Reply With Quote
Old 03-20-2012, 11:01 PM   #6
ARC Painting's Avatar
Are these latex or oil based paints? I'd suggest disposing of them, if they are a nuisance and not usable. If latex (water-based) you can pour it out over plastic to air dry. If oil, you should take to a city waste-disposal depot.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 03-21-2012, 04:26 PM   #7
Mr. Paint's Avatar
Bacterial contamination can cause a lid to come unsealed. You can kill the bacteria with a tablespoon of hydrogen peroxide but, the paint is unusable. If you have a solvent issue (Oil-based paint) buy some new metal containers for it. Your county disposal/recycle company can direct you how to legally dispose of the product(s).
Mr. Paint is offline   Reply With Quote
Old 03-21-2012, 04:44 PM   #8
He hasn't been back- so he probably found a bag of garbage he forgot to take out...
Old 03-21-2012, 05:13 PM   #9
Mr. Paint's Avatar
Or a dead cat...
Old 03-21-2012, 06:01 PM   #10
Just a DIY guy
or he is face down in the garage ...
M3 Pete is offline   Reply With Quote
Benjamin Moore Natura paint smell won't go away sbrackett123 Painting 9 11-04-2016 11:04 AM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 07:52 PM
