Paint The Shower Tile - Painting - DIY Chatroom Home Improvement Forum
Old 12-05-2007, 09:33 PM   #1
paint the shower tile
Is there a paint that would hold to shower tile and if so what type of preperation would be necessary?
brucejill is offline   Reply With Quote
Old 12-05-2007, 10:05 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Not really no
Regardless of the claims of some manufacturers, and some DIY magazines, there's very few products that might hold to that surface in that environment
The only ones I'd say for sure are the modern modified epoxies
The BIN (shellac) and XIM (dunno what that is) primers can hold, but no guarantees
You'd need to clean and scuff sand and clean again
The use the primer
Then use one tough 'paint'...like an enamel
I'd recommend going for the re-tile unless you are going for an artistic look
If you are going for the easy money saving way, I don't think coating them will be either
slickshift is offline   Reply With Quote
Old 12-06-2007, 10:45 PM   #3
Call a reglazing company. The one I use charges about 380 for a bathtub, and about 500 for a stall shower. They warranty them for 5 years. I THINK it is a similar material to automotive paint that they use.
send_it_all is offline   Reply With Quote
Old 12-07-2007, 08:10 PM   #4
I do real estate management and use a company called royal finish. They can re-glaze tile and tubs. They charge about $400 for a tub and are a nationwide company. I believe they are based out of Texas.
skinnyj41004 is offline   Reply With Quote
Old 12-07-2007, 09:30 PM   #5
slickshift's Avatar
I have seen those pro outfits work wonders
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
Building a tile shower ghostrider20 General DIY Discussions 2 03-01-2007 09:54 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
