Paint For A Semi-wet Area... - Painting - DIY Chatroom Home Improvement Forum
Old 11-07-2008, 07:22 AM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Paint for a semi-wet area...
HI;
I think at this point I am fairly commited to putting up plaster board with a couple coats of veneer plaster on it. (for my remodeled, now fully enclosed part of the house porch)
The only concern I have with the veneer plaster is that it says on the USG site that it is not as water / mositure resistant as traditional plaster.
The concern is that I am putting a hot tub / spa in this room. It is also our primary entrance from the garage and to the outside patio, which are both heavily trafficed. The room is above grade by about 7 inches, all proper construction. I am just concerned really about moisture that may be in the room from the hot tub, slight splashing, etc.
I was thinking about using a bathroom primar and paint, like the BM line.
How much water resistance can I get with a good paint? Are there any better choices for water resistance than the BM bath paint?
Should I think about using the zinsser bathroom primar first?
It's going to be a while before I paint this room, but I want to make sure I can make it some what water resistant before I start putting in this veneer system...
Jamie
jamiedolan is offline   Reply With Quote
Old 11-07-2008, 09:46 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I think you have the right ideas. Get a good quality primer and bathroom paint. Ignore the statement on the bathroom paint that it self-primes. Nothing primes like primer.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
