Paint That Sags - Painting - DIY Chatroom Home Improvement Forum
Old 07-04-2008, 12:17 AM   #1
Rewards Points: 35
Paint that sags
My exterior oil primer (SW A100) applied on 2 vertical redwood siding pieces has sagged in 3 places. It was brushed onto old redwood that was stripped of previous paint/primer, sanded, cleaned, etc.
Is sanding the proper way to remove the imperfection? Or, should paint stripper be used in the 3 areas?
Should I have rolled this primer? Should I have thinned the primer?
Thanks in advance for any suggestions.
TVC15 is offline   Reply With Quote
Old 07-04-2008, 01:19 AM   #2
Rewards Points: 2,906
I would just scrape off those sagged areas with a sharp paint scraper and repaint.
Thinning your paint is good practice in my books because it BOTH lowers the viscosity of the paint so that it self levels faster and dilutes the paint so that it takes more time for the thinners to evaporate, thereby creating better conditions for the paint to self level on horizontal surfaces so that you don't see any brush strokes.
The problem is that by thinning latex or oil based paints, you also create better conditions for the paint to sag as it dries on vertical surfaces.
I've been told that using a paint conditioner like the Flood Company's "Penetrol" for oil based paints and "Floetrol" for latex paints thins the paint without lowering it's viscosity, so that you prevent sagging in the paint on vertical surfaces. However, I've never tried either product when painting vertical surfaces to see if it works that way. If you try it, and it doesn't work, then keep thinning your paint, but apply thinner coats to eliminate sagging.
Nestor_Kelebay is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Painting a garage door dfoxworthy Painting 6 06-22-2008 11:51 PM
Dark to light/neutral couchguy Painting 3 06-20-2008 01:07 AM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
