Old 05-19-2009, 02:54 PM   #1
Haste Makes Waste
Paint Rollers & Sleeves
What makes the sleeve want to keep work its way off the roller???
saggdevil is offline   Reply With Quote
Old 05-20-2009, 05:30 AM   #2
paper hanger and painter
chrisn's Avatar
Cheap sleeve and or roller.
Old 05-20-2009, 09:53 AM   #3
A cheap roller frame will do this. Spluge the $6 or so at HD, and get yourself a Wooster Sherlock. That roller sleeve won't go anywhere.
sirwired is offline   Reply With Quote
Old 05-23-2009, 09:51 AM   #4
Haste Makes Waste
Sirwired....thanks for the advice. I got a Wooster Sherlock and am using Purdy White Dove sleeves. It makes an incredible difference. Just didn't realize there was such a difference in paint tools, but then I'm fairly new at this. I've only painted a room or so in past, now I'm doing my whole house inside....on room 4 downstairs. (4 more to go downstairs...lol)
Also got Purdy angle cut brushes for trim. BIG difference in previous brushes I've used.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
