Paint Remover Exterior Windows - Painting - DIY Chatroom Home Improvement Forum
Old 09-01-2007, 02:19 PM   #1
Rewards Points: 150
paint remover exterior windows
Hello
I'm about to venture into a project as soon as the weather cools off here in
Mich. 88 degrees, My daughter has 27 windows a couple need sill repair others are wood bare and in need of simple care and preparing for the primer coat.
I don't want to use a heat gun near the glass this may crack the glass and also they are thermal sealed.
Could I use paint stripper along the molding next to the glass?
deck hand is offline   Reply With Quote
Old 09-01-2007, 03:53 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Depends on the exact type of windows and what they used or sealing...and what the manufacturer says about it
But usually it's just scrape and sand
Unless the glass is glazed, and can be re-glazed
You can only do so much and play it safe with windows
slickshift is offline   Reply With Quote
Old 09-01-2007, 07:34 PM   #3
Rewards Points: 506
Why do you want to strip the existing paint? Certainly scrape and sand to remove what is loose, but why take off the paint that is adhering well?
SirWired
sirwired is offline   Reply With Quote
Old 09-01-2007, 08:29 PM   #4
Paint/Faux Artisan
Da Vinci's Avatar
I wouldn't use remover next to glass- may mess up factory seals. Just scrape and sand - prime it and they'll look great.
Bay Area Painting Company
Da Vinci is offline   Reply With Quote
Old 09-02-2007, 02:27 PM   #5
Rewards Points: 150
Will go with just sanding, washing and prime
Deck hand
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 06:45 AM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
my painter did not fallow the contract jaskoo Painting 17 11-19-2006 01:21 PM
