Paint Removal - Painting - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 05:48 PM   #1
paint removal
I'm looking for information on how to remove paint from a cultured marble counter top
Ron the fixer is offline   Reply With Quote
Old 08-06-2009, 06:25 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 390
goof off?
chrisn is online now   Reply With Quote
Old 08-06-2009, 06:35 PM   #3
goof off
I've never heard of this product. I'm in CA - do you know if its a national brand? Will it damage the cultured marbles' finish?
Old 08-07-2009, 04:48 AM   #4
chrisn's Avatar
Rewards Points: 390
Yes it is available where ever paint is sold and no it should not( test a small area to be sure)
Old 08-07-2009, 07:27 AM   #5
ccarlisle's Avatar
"Cultured marble" is more of a plastic product than stone, polyester I think, and therefore has little to do with 'marble'. It may contain marble dust, but either way won't be affected by paint strippers. Solvent blend removers shouldn't penetrate into the product but test to make sure.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-07-2009, 09:01 AM   #6
chrisn's Avatar
Rewards Points: 390
I just assumed it was real marble( should not assume) if it is any type of plastic, goof off will eat it, do not use.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
