Paint Removal - Painting - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 12:25 AM   #1
jstar571's Avatar
Paint removal
I need ideas on removal of some really old ugly green paint on some stained (I think) wood. It's all over the house on every trim & window
Or should I replace the wood?
jstar571 is offline   Reply With Quote
Old 06-08-2013, 03:41 AM   #2
Rewards Points: 12,856
Got some pictures.
Confusing post, "ugly green paint on some stained I think wood?
Why not just prime and paint over it?
Old 06-08-2013, 06:43 AM   #3
Jmayspaint's Avatar
Rewards Points: 534
Joe, I got a feeling he's talking about the all too common Non bonded trim paint. Ya know, it chips, it flakes, probably latex over varnish like he's guessing. Been hearing about that a lot.
Jmayspaint is online now   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
oh'mike (06-08-2013), user1007 (06-08-2013)
Old 06-08-2013, 07:44 AM   #4
Too Short? Cut it Again!
Well, I will hype it again. The infrared stripper I got was one of the best tools I ever purchased. Pricey but made short work of stripping interior and exterior wood. Easy to use and safe. You can rent them.
That said, if it is crappy latex paint over non-priimed varnished wood, you can usually get most of it off with a SHARP drag type scraper and contour scrapers and sand paper.
The goal when stripping wood is to keep the heat you generate to a minimum whether through friction or chemicals. The more the heat the more you risk forcing melted paint into the grain.
Old 06-08-2013, 08:50 AM   #5
jstar571's Avatar
Here is the color
Old 06-08-2013, 08:55 AM   #6
http://www.stortz.com/catalog.asp?prodid=681105
Old 06-08-2013, 09:01 AM   #7
Gymschu's Avatar
Rewards Points: 230
Looks like it was painted before. Paint it again in the color of your choice. Invest in some "Goof-off" latex paint remover to get some of the paint off the good wood. Otherwise, have at it!
At least I think you are talking about the slivers of paint someone slopped onto the good trim. "Goof-off" is the best of the gentle latex paint removers. Pour some on a cotton rag and rap the rag around a putty knife and work it up and down against the trim to remove the excess paint. Yes, you will need some elbow grease and lots of time.
Old 06-08-2013, 09:03 AM   #8
jstar571's Avatar
I thought/hoped there was one layer of paint but there is at least 2. I want wood stained wood look so I'm pretty screwed I think
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
