Paint Recomendations - Painting - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 05:05 PM   #1
Talking
Paint recomendations
I have a two yr old house and the paint on my window sills is pealing. The sill seems to be made out of recycled and compressed paper! I would like to redo the window and door trim as well as the base boards. (same material). I would like the finish to be very high gloss and hard. Like plastic. What kind of paint should I buy and what kind of preperation should I do? characters left:
wrek is offline   Reply With Quote
Old 02-12-2009, 05:19 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Scrape any loose paint off
Feather sand any uneven areas smooth, scuff sand (light sand) the rest
Spot prime and bare "wood" (or whatever that is)
-As it's unknown, I'd use an alkyd/oil primer if available
Prime the whole thing if the "spots" are excessive
Coat with a quality enamel
...or in your case, you may want to use Ben Moore's Aura (technically not an enamel but is really, really, hard) which only comes as glossy as a semi-gloss, but is also great for problem areas and should be available in your area
Other-wise, a good quality (water-based) high gloss metal & wood enamel should do it
slickshift is offline   Reply With Quote
Old 02-12-2009, 05:22 PM   #3
slickshift's Avatar
...please keep in mind that the glossier the finish, the "more perfect" the surface has to be
Paint colors, but does not (realistically) fill
The shinier the paint, the more imperfections will show
Old 02-13-2009, 10:53 PM   #4
The only thing I'd add to Slickshift's responses is that I'd implore you to find an oil primer for this project: Do not skimp or cheat there. The higher the water-content in this matter, the easier it would be for a product to eat the adhesive or swell the fibers of what you're describing and break it down further. My hunch (opinion, without seing it) is that your generous builder didn't use a primer at all.
Steve30 is offline   Reply With Quote
Old 02-14-2009, 09:26 AM   #5
As was said, surface prep is very important. If you want a smooth finish, you need a smooth surface. You can even lightly sand between coats. You may need an additive to the Ben Moore to help it layout cause it is a bit thick. I must say it is an excellent paint and does leave a nice plastic-like layer. Best paint I've used so far.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
