Old 11-05-2011, 01:07 PM   #1
Paint Pulled Off With Tape
When pulling off the tape from my walls, some of the paint pulled off in sheets, right down to the white painted wall underneath my new red paint in some areas. Unfortunately, I had to use several coats of paint because I was painting over builder paint for the first time and so there is a pretty large difference where the red edge pulled away and the original wall.
I am wondering what the best way to fix this might be. Should I sand the areas where this happened (tricky because it is between the wall and ceiling, seems like it would be difficult to sand) or should I try some spackle to even it out, then repaint?
I used Aura paint and the green frog tape. I pulled the tape after I finished all of the coats I needed in the whole room, so about three days total.
This was a big enough job without this problem and I am not sure what to do. :-(
AllBoys is offline   Reply With Quote
Old 11-05-2011, 04:33 PM   #2
paper hanger and painter
chrisn's Avatar
Do a search. This has been covered numerous times, in fact more than numerous.
Old 11-06-2011, 06:07 AM   #3
Part of the problem may lie with the builder's flat, which has a tendency to chalk. The chalkiness will give adhesion problems when removing tape. It's good practice to seal builder's flats with a good primer prior to finishing, one that has ability to adhere to chalky surfaces. Get off the tape, it's a drug. Check my blog for a tutorial on painting without using tape. Free yourself. Prime the peeled areas, spackle if necessary, reprime, then finish.
Old 11-06-2011, 06:59 AM   #4
the Musigician
DangerMouse's Avatar
Especially the frogtape.... I hear people are licking it........
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-06-2011, 08:38 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
JS- You always tell people to not use tape- but I don't agree when gravity and roller spatter (IE- base) is involved.
If trim is already finished ( and I finish trim first when doing both) I tape base always. Why spend the time cleaning paint off? I use a handmasker and 3" paper most of the time, and tuck a drop under the paper.
Agree on sides of things as far as a brush cut.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-06-2011, 08:47 AM   #6
I agree. I do use tape, but not to cut lines. It does serve a masking purpose.
Old 11-06-2011, 09:05 AM   #7
I guess here in DIY land- it might be helpful to make that clear.(er)
Most of the time it sounds like you are saying never use any.
Old 11-06-2011, 10:23 PM   #8
Roger that.
Old 11-08-2011, 01:13 PM   #9
Windy Painters
Windy Painters's Avatar
Send a message via Skype™ to Windy Painters
At first prime damaged areas - Zinsser 123 should be enough. Spackle and sand with sponge. Prime again and paint. For cutting ceiling lines is better to spend $20 for good brush instead of 20 for 2 rolls of tape which damage the finish. Good luck
Chicago painter
Hyde Park painter
Windy Painters is offline   Reply With Quote
Old 11-11-2011, 02:24 PM   #10
Speaking of gravity and baseboard: the one place gravity works against you when cutting wall paint is against the top of the baseboard. (It works against at the top of doors and windows too, but 90% of the time who cares about perfection there?) Not talking about drips - talking about gravity dragging your paint line edge down.
If I'm painting the trim, I paint most trim first, then the walls, then baseboard last. This allows me to be non-perfect when cutting wall paint against the baseboard. Then paint the baseboard with gravity in your favor (and the baseboard acts as a physical guide for the brush) and you get a perfect line. No tape required anywhere for this method.
When not painting the trim, then masking the top edge of the baseboard (the 1/8" ledge) works well, then cut the wall with a relatively dry brush. I use this with good results.
http://tinyurl.com/86o6sny
The tape goes on first thing (might as well) to avoid drips as brushjockey mentions.
jeffnc is offline   Reply With Quote
Old 11-11-2011, 10:08 PM   #11
You painted over the tape and left the paint dry on the tape. If not removing the tape right away before you need to take a razor blade and cut a line between the paint film and the tape. Always remove the tape as you paint
jayhawks is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
Paint is peeling off when I lift masking tape! Help! HelloMotto Painting 10 07-15-2009 09:53 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
