Paint Problems - Painting - DIY Chatroom Home Improvement Forum
Old 07-26-2009, 03:17 PM   #1
Question
Paint problems
Paint in bathroom is only 3 years old, does anyone know what kind of problem this is? It will not come off, only around bathroom sink area.
mzlvschoc is offline   Reply With Quote
Old 07-27-2009, 04:08 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
http://www.essortment.com/home/howtoremovesu_scdd.htm
Old 07-27-2009, 06:45 AM   #3
ccarlisle's Avatar
A 3-yr old paint job? Has this just happened recently, or has it always been there? does it only happen sometimes or only around the sink area? Do you remeber what brand/type of paint?
What was the substrate? drywall? painted drywall? are there kids in the house?
I wonder if chrisn would agree that surfactant leaching should not be an issue after 3 years - and not necessarily located in one spot like that. What do you think?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 07-27-2009, 11:23 AM   #4
This has just happened in the last 3 weeks. I have a window in the bathroom, so its not a moisture issue. Paint is 3 years old painted on new drywall. This area is behind the splashguard on the wall, no where else in the 100sq foot bathroom. The paint is Frazee SatinGlide II Semi Gloss paint
Old 07-27-2009, 02:05 PM   #5
chrisn's Avatar
Rewards Points: 612
[/quote]
Should'nt be, but? I would try all the steps provided in the link and see what happens, maybe it will all go away. If not ,then you need to re-paint.
Old 07-27-2009, 04:12 PM   #6
Rewards Points: 252
kind of a mystery - it certainly looks like surfactants - the only thing I can think of is with the high summer humidity (where are you located) maybe something triggered? Is it the exterior wall - maybe the insulation has failed behind this wall? The three year part is stumping me, can't see why that wouldn't have popped up the first two summers the bathroom was painted. I think Chris said it best, try cleaning and if not repaint. Try the Aura Bath and Spa paints - do NOT use the Aura Matte or Eggshell.
good luck
mazzonetv is offline   Reply With Quote
Old 07-28-2009, 06:28 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Surfactants are usually darker spots. That sure looks like something got on the walls and ran down like maybe some rubbing alcohol.
Old 07-28-2009, 07:33 AM   #8
ccarlisle's Avatar
Yup. Surfactant solutions are like a MacDonalds restaurant to bacteria...they feed there for next to nothing, many of them die there, turning the solution black.
Old 07-28-2009, 02:42 PM   #9
Rewards Points: 356
My money is on some type of cleaner that splashed on the wall...
RegeSullivan is offline   Reply With Quote
Old 07-29-2009, 03:07 AM   #10
chrisn's Avatar
Rewards Points: 612
That or something like hairspray,soap,etc would be a good guess, either way it needs to be cleaned and or painted again.
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
peeling paint on plaster ceiling mspdet Painting 9 12-13-2008 07:45 PM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Ceiling paint problems, and color? mara Painting 6 08-02-2008 02:23 PM
