Paint Problem On Exterior Furniture - Painting - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 07:36 PM   #1
Paint problem on exterior furniture
I ran into a problem painting some exterior furniture and am not sure how to fix it. Was hoping I could get some help here.
I first scrapped all the peeling paint off. I then sanded with 180 grit. I then sprayed on a couple coats of a water borne automotive primer. Sanded with 220 grit then applied a urethane automotive paint. Within one week I saw signs of peeling and bubbling. The color of the paint is black. Seems the problem is only were the sun light hits the surface directly. I replaced a few bad boards on some of furniture and they seem to be holding the paint fine. I am thinking I am having a problem with the sun heating up the black finish, expanding the wood and maybe steaming the moisture out?
I would appreciate any help
Thanks Dave
Dave P is offline   Reply With Quote
Old 09-02-2009, 04:18 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
I don't know but I do not think automotive paint was ment for wood.
Old 09-02-2009, 07:10 AM   #3
HI Chris,
I use automotive paint on wood all the time. This is the first time I have used it on wood that was old, out in the elements and black finish. I have sprayed automotive paint on exterior steel doors with wood edges on the door and wood door jambs with no issues many times. The paint seems to be sticking to the primer, but the primer seems to be letting loose from the bare wood and the old paint. I wonder know if I should have used some kind of bonding agent first.
Dave
Old 09-02-2009, 08:34 AM   #4
chrisn's Avatar
Rewards Points: 230
Well, if the primer is letting go then as you said it might be a moisture problem and with it being black, this will just intensify it.I think I would still go with a slow dry oil primer and a 100% acrylic topcoat of exterior house paint if it were me.You may have had luck with the automotive paint sticking to some metal trim but I still do not think it was made to stick to wood.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Never had a paint problem till now jackie treehorn Painting 6 07-09-2009 05:53 PM
problem - latex paint over oil paint theis96 Painting 3 03-14-2009 01:44 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
