Paint+Primer Work On This Situation? - Painting - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 07:42 PM   #1
Paint+Primer work on this situation?
Please consider the attached picture.
Prior to painting, the plan will be to powerwash and scrape as much loose paint as possible.
Would you consider the paint+primer paints such as Dutchboy DuraWeather MaxBond or Valspar Duramax, etc would work on this surface? I anticipate the best answer is to get a higher end primer and paint and do them separately, such as a Ben Moore or Sherwin. Will the Dutchboy or Valspar at least cover it adequately for a few years?
chubbsub is offline   Reply With Quote
Old 09-15-2012, 08:12 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
You can roll the dice. I wouldn't.
And you need to figure out why that paint is pealing.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-15-2012, 08:33 PM   #3
Gymschu's Avatar
Rewards Points: 922
Dutchboy blows, VaLspar's ok. For all the effort you're going to be putting into it, why do the 2 year plan?
Old 09-15-2012, 09:10 PM   #4
The 2 year plan...?
Well, I'm having a new roof put on at the same time and the remainder of my budget will not support doing Ben Moore primer then paint. The intent would be to sell very soon.
Old 09-16-2012, 01:58 AM   #5
Too Short? Cut it Again!
It looks like there is no primer under the paint now so most of it will come off when you powerwash I suspect. No such thing as paint and primer in one so if you use any of the products do not expect much. Dutch Boy is SW's box store brand and Valspar is what it is. I would use a contractor grade from an SW or Ben Moore store before using either.
You might think about Sherwin Williams Woodscapes Solid Acrylic Stain. It is not exactly cheap either. You can get it mixed to any color and will not require a primer. You can put it over exposed wood or previously painted. I would feel confident it would last two years.
Just a comment and I know budget is tight. If you brag about the house being recently painted in the sales literature and can brag about the paint used? It becomes a major selling feature. Make sure to rake up and bundle those chips so people do not see how bad the paint on it now is doing a walk around.
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (09-16-2012)
Old 09-16-2012, 07:12 AM   #6
Since you have chipped/loose paint, you might want to consider using a high quality bonding primer such as Mad Dog Primer. It's expensive ($70/gallon) but the way I look at it, it's your labor that is the most expensive part. Paint is cheap compared to the drudgery of painting, scraping, spackling, sanding, etc. Something that I don't want to have to do any time soon again.
diycoder is offline   Reply With Quote
Old 09-16-2012, 07:29 AM   #7
Rewards Points: 13,950
http://www.sherwin-williams.com/home...ling-cracking/
Old 09-16-2012, 07:53 AM   #8
A Little Of Everything
Rewards Points: 1,364
Either of them will work, assuming you have the surface scraped and dry. Will you have an awesome, long-lasting finished product? Probably not, but it will be okay - at least for awhile.
4 years ago I was running out of time to paint a backyard shed I had built. Late fall, storm moving in that weekend, etc. I picked up a gallon of Behr (GASP!) primer/paint at the nearby Home Depot (GASP GASP!!!!!) and threw it on. It's a dark color, matching our brick house. This many years later, it still looks as good as it did when I first applied it. No chipping, peeling or fading. Go figure.
DrHicks is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
primer included in paint... does it work don50 Painting 11 09-13-2011 01:35 AM
Stucco over paint, will Primer work ? iMisspell Building & Construction 5 05-14-2009 04:07 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
