Paint Primer - Painting - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 10:44 AM   #1
Paint primer
Had prepared walls with some type of primer for wall paper 25 yrs ago. I have pulled the paper off and repaired the walls. It seems the walls because of the repairs is taking the paint differently in areas. I think I need a primer. Are all primers the same. I am using a Benjamin Moore flat latex paint. Any suggestions.
Melw365 is offline   Reply With Quote
Old 09-16-2012, 04:46 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Gardz or Cover Stain where there was paper removed
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (09-16-2012)
Old 09-16-2012, 04:54 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Chris is right- and here is why.
First- did you remove as much paste as you could? very important because it will be "lumpy" and can, even through regular latex paint- reactivate and expand.
And your repairs with mud/spackle will absorb differently than just painted walls.
What Gardz ( water base) or Cover Stain (Oil based) will do is seal in both and make a vapor barrier that will not allow moisture, either from the top coats of paint or the atmosphere- to penetrate and cause trouble later.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
How paint primer actually works? konsole Painting 4 11-11-2010 04:48 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 08:13 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
