-   -   Paint peeling off tile (http://www.diychatroom.com/f4/paint-peeling-off-tile-182110/)
crescere 06-19-2013 12:04 PM
My basement had moisture issues, so I put in a good dehumidifier which is working well in that I do not have any musty odors. However the odd thing is that now much of the paint on the ceramic wall tiles is peeling off throughout the basement. I do not know what kind of paint the prior owner used. The tiles look good underneath the paint so I do not know why she painted them in the first place. Why is this happening and do I now have to paint all of it correctly to get an even color and stop the peeling look?
Jmayspaint 06-19-2013 12:46 PM
Wow, that is odd... Sorry I don't think I can help much except to say you will probably need to strip the tile and start over.
Interested to see if anyone has any ideas on how lower humidity could cause peeling. I suspect the paint was never bonded to begin with, and somehow the humidity change caused it to peel.
In an area where its not peeling, see if you can easily scratch the paint off with your fingernail or a butter knife.
user1007 06-19-2013 02:15 PM
When you say ceramic wall tile what exactly do you mean? Is this in a downstairs shower or something?
Painting tile ranks right up there with painting wallpaper and should not be done. It does sound like the prior owner was tired of the color or something or needed to hide something to get the home sold. I am guessing she also applied paint without a bonding primer.
Getting primer and paint to stick to tile in a wet environment is tricky. Paint will peel as fast from lack of humidity as it will with too much---maybe more so. In the case of tile, you have a material that cools and heats fairly quickly and the paint is just not stretching/expanding or shrinking/contracting with it. If this was a cosmetic band-aid job I just bet it was also cheap paint to start with.
Scrape off all the peeling paint and apply a bonding primer if you are stuck painting the tile again. Then apply two coats of finish. This will be a regular maintenance chore if the tile is in a shower area or something.
If the tile looks good underneath, you might think about renting an infrared stripper and taking all the paint off? You might have to deal with the grout but it would be a better long term solution than priming and painting it.
Gymschu 06-19-2013 02:18 PM
Painting ceramic tile is dicey at best. If a good bonding primer was not used, the paint had little to no chance of sticking for very long. It may just be coincidental that they are peeling after you put in the dehumidifier. This could be one of those times where a HO, for a quick sale, dressed up the tile with a quick paint job to get the house sold, not paying much attention to proper prep work.
chrisn 06-19-2013 05:01 PM
I agree but I bet it will be argued:whistling2:
ToolSeeker 06-19-2013 05:17 PM
Gee by whom.
crescere 06-19-2013 09:36 PM
I have had this house for more than four years and the paint did not start doing this till a few days after I put in the dehumidifier about two weeks ago.
No this is not a shower area. It is just a finished area with a gas fireplace.
ToolSeeker 06-20-2013 06:31 AM
It could be just the big change in the humidity levels dried the paint out more.
user1007 06-20-2013 07:10 AM
If it has been on for 4 plus years and without a primer under it, it may just have reached the end of its life and the peeling is mostly coincidental. Dropping the humidity just accelerated the process a bit perhaps.
crescere 06-20-2013 09:31 AM
How do I get the rest of the paint off the tiles or do I need to do that?
ddawg16 06-20-2013 09:33 AM
Originally Posted by ToolSeeker (Post 1204079)
Gee by whom.
I'm sure they will be along shortly.....they most likely saw it on "Design on a Dime"....hey...it looked good on TV....(no one said it had to last)
crescere 06-28-2013 08:25 PM
Does anyone have ideas on how to get the rest of the paint off so I do not have this peeling mess? Eventually it may all just peel off on its own, but that may take a while.
MTN REMODEL LLC 06-28-2013 08:44 PM
Gee by whom.
OK...OK... I'll fess up...I've done it.... and I'll bet 50% of you all have.
In my personal home, many years ago... original owners had not sized anything... and we removed alot of the paper with finger nails and strips 1/2 wide and 3" long (1978 build, we bought 1985).
As best I can recall, I think I glued any loose seems, hit it with an oil base primer (cover stain maybe), orange pealed it, and painted it. IT HAS BEEN FINE FOR 25+ years.
I would not recommend it .... but I did get away with it.:yes:
Best...
Peter
user1007 06-28-2013 09:44 PM
I think I already mentioned an infrared stripper. Expensive to buy but hard to rent since demand for them backs up this time of year. If you buy one, you should be able to get almost what you paid for it back when you are finished.
