Paint Peeling Off Dresser That Was Just Painted - Painting - DIY Chatroom Home Improvement Forum
Old 03-04-2009, 02:08 PM   #1
Paint peeling off dresser that was just painted
Help! I just painted a dreser wtih latex paint and after drying - it is marking and easy to peel off. I prepped the dresser by using TSP, used steel wool, tack clothed, and then primed beofre painting.
Is there another product I can paint over top make the surface more durable. Thanks
samk is offline   Reply With Quote
Old 03-04-2009, 03:20 PM   #2
Remodeling Contractor
Seems like you used cheap paint. But nothing painted over a bad paint job will fix it.
Old 03-04-2009, 03:56 PM   #3
Rewards Points: 506
Two questions:
1) Did you rinse the TSP? It leaves behind an adhesion-harming film if you do not.
2) What primer did you use?
Unfortunately, you usually cannot coat a topcoat with something to enhance adhesion. Durability, yes; adhesion, no. There are some rare exceptions, but this isn't one of them.
SirWired
sirwired is offline   Reply With Quote
Old 03-08-2009, 01:35 AM   #4
Try Stripping the old paint coat and refinishing it with a new paint.
In the case of furniture and cabinets, improper stripping can raise the grain of the wood, requiring extensive sanding. Paint stripping by applying a chemical substance to dissolve the old paint is usually the preferred method on fine wood.
Once it's had a chance to work, you can simply scrape or wipe away the old coat and prepare the wood for your next finishing choice.
Goodluck with it!
Dana
Dana11 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
