Paint Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 04:44 PM   #1
Paint Peeling
I think my hallway doors have an oil based paint on them because I've painted over them before without sanding first and the sateen lustre paint I put on peeled right off. I really don't want to sand all my hallway doors, so my question is: Can I prime over an oil based paint then paint on a Behr Sateen Lustre without the paint peeling off?
mefinnigan is offline   Reply With Quote
Old 01-10-2009, 08:30 PM   #2
Remodeling Contractor
no this paint is no good and it will peel off. Over oil base you can paint latex or oil. over latex you can only paint latex. So this is not your problem. Do not want to sand. Then wipe them down first with wilbond. It is a liquid sander. This will help the paint stick. But stick to some quality paint. The better binder is what makes the better paint more expensive. A quality paint will cost over 35 a gallon. You will always get what you pay for in paint. So buy the good stuff unless you are painting for the fun of it.
Old 01-10-2009, 09:12 PM   #3
Thumbs up
Wil-bond
Thanks for the Wil-Bond idea. I did a search for it on the Home Depot and Lowes websites and had no immmediate luck finding it there. I'll have to do a walk-in to the stores to see if I can find it someplace. However, I did find some information about it just surfing around and it does seem like the way to go! Thanks again, I hate sanding!
Old 01-11-2009, 12:14 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
If it were me and it was already painted with oil, I would keep painting it oil. It looks nicer and last a bazillion times longer. If I were making the transition from oil to latex, then I would give it a good coat of oil based primer. You can coat anything over oil based primer.
Old 01-11-2009, 11:26 AM   #5
Rewards Points: 506
Matthewt,
The new Waterbourne enamels have the toughness of oil paint, without all of the application drawbacks. You might want to give them a try.
To the OP,
Give the existing paint a scuff sand, clean off the dust, prime with an oil-base primer, and then topcoat with the quality paint of your choice. (Behr isn't a quality paint.) SW ProClassic and BM Impervo Waterbourne are excellent choices for a trim coating.
SirWired
sirwired is offline   Reply With Quote
Old 01-11-2009, 12:05 PM   #6
Originally Posted by sirwired View Post
Matthewt,
To the OP,
SirWired
IMO this is also good advise. Many painters are stuck on oil. But Latex has greatly improved in recent years and is just as good. But again, use only the quality brands from a paint store. Big box stores will not have any quality paint.
Old 01-11-2009, 03:17 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Short answer:
No
In reality....sometimes latex over oil works
However, it is not a good idea
The proper, fool-proof, fix is:
Scuff sand the doors
This is NOT a big deal
You are not sanding the finish off, merely giving the next coat something to hang on to (some "tooth")
So that's a quick, light, sanding
Wipe clean, then prime with a premium quality alkyd (oil) based primer
(not Behr)
Then top coat with two coats premium quality waterborne enamel
(again, not Behr)
Then, when you want to paint again, just a quick scuff sanding, wiping, and quality enamel will be fine
slickshift is offline   Reply With Quote
Old 01-11-2009, 11:41 PM   #8
Matthewt,
To the OP,
SirWired
I have used the BM line of Waterborne Enamels and they are good. And believe me, I am all for water based paints, or water reduceable paints, but in this case he is still going to have to scuff sand, clean, prime with oil, then coat with the Waterborne Enamels, or he could just paint it with an oil based paint.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
