Paint Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 07:45 PM   #1
Paint peeling
I was asked to paint the ceiling in a small room... when I looked at the ceiling it appears that the paint is peeling off. A closer look it appears that there is latex over oil (cannot say for sure). Dull thin paint peeling off reviling shiny (semi gloss?) thick paint. I have tried sanding it and more peeled off. Any suggestions on what would best plan of attack here?
lakec is offline   Reply With Quote
Old 10-19-2011, 08:39 PM   #2
Gymschu's Avatar
Rewards Points: 932
Scrape as much of the top layer off as you can using whatever works the best for you whether it be a 2", 4", or 6 inch blade scraper (putty knife). Sometimes a razor scraper works even better although it can gouge the wallboard/plaster. Sand the glossy surface underneath, clean, then prime with a bonding primer such as Zinsser's 1-2-3. Allow to dry. Then, skim coat with joint compound to bring the ceiling back to "flush." Sand, the compound, remove dust, and prime with drywall primer. Allow to dry and then topcoat with one or two coats of a finish paint of your choice.
Old 10-19-2011, 08:55 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Gym- You should copy that- It's a pretty good answer to about 50% of the q's here!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (10-20-2011)
Old 10-20-2011, 07:49 AM   #4
Gymschu's Avatar
Rewards Points: 932
Ain't that the truth, Brushjockey...........I think if we all copied our answers we could probably cover about 95% of the questions asked here at DIY!
Old 10-20-2011, 04:36 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
And just think, big Joe sits down a writes journals about this stuff
More power to him
The Following User Says Thank You to chrisn For This Useful Post:
Old 10-21-2011, 06:45 AM   #6
I use a six inch flexible, thin blade, spackle blade. From scraping ceiling/walls, it has a razor edge and gets nicely under the failed layer and doesn't gouge.
Chrisn, "those who hear not the music, consider the dancer mad".
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
