Paint On Paint - Painting - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 12:48 PM   #1
Paint on paint
Whoever repainted the walls in this house did some quick mudding and sanding in places and not in others. The surfaces I'm now looking at vary from smooth to grooved to lumpy and any paint put on top of this will just look the same. Removing the drywall and starting again is a very last resort. I've noticed that the "bumpiest" surfaces are right above the radiators, so it begs the question; is there an optimum drying temperature for a smooth painted surface? My main question is how do I prepare an already (poorly) painted wall for a repaint?
Thank you
Terry M
ddr1826 is offline   Reply With Quote
Old 03-07-2008, 12:53 PM   #2
looks like destroy the bumpy area by knocking out some sheet rock and refill it with layers of mud and sanding is the only choice you left with....
but you got to have the brave heart to destroy the piece sometimes.... applying mud on top of a bump up area can't always fix the problem....
KUIPORNG is offline   Reply With Quote
Old 03-07-2008, 03:25 PM   #3
Penniless Parent/HO
Terry, There is a lot of what you describe in our house. This can happen when there is a time constraint on the paint job. Wall prep is left incomplete and paint application is started so as to complete the job by a specific time. In our case, wallpaper removal, poorly attached built-ins and wood paneling all have played roles in this. Sometimes an oil-based primer over the existing paint can smooth over smaller irregularities. All too often we have to skim coat large portions of the wall. This requires multiple coats of joint compound with overnight drying between coats. Add in the sanding mess so you can see why it's easy to skip this. If you opt to replace drywall you'll still have to tape the joints and mudd the screws so you may not save much time. Plus you'll have to transport the new drywall and dispose of the demo. If other forum contributors have better ways to solve this problem, I am also very interested.
Mike
mikebal is offline   Reply With Quote
What's your "favorite" tip, when using "oil base" paint? Bobrobert Painting 15 01-17-2008 11:36 PM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 10:29 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
