Paint On Outside Door Trims Peeling (Again)
I painted my outside door trims white 3 years ago with Sherwin Williams All Surface Enamel Oil Base Gloss White.
It is already peeling. I also wire brushed and wiped it down good when I did it. They are now needing to be repainted for the third time in the 10 years I've owned this new home. What is going on with this? |
have you been using any primer? a wire brush is fine for removing some of the loose paint. you should also sand the surface to provide a profile for the paint to bite to.
After hearing that I am a little angry that a sales person at a paint store where paint is the only thing they sell didn't qualify me better on my purchase by asking me what I was using it for and thus could have recommended primer and any other technique I needed to use to get the most out of the paint to save me some troulbe. As a result I have trouble and am writing Sherwin Williams about my experience. Thanks. |
If you just went in and bought th paint, then they thought you knew what you wanted and what you were doing,apparently this was not the case. |
Sorry, but three years is about all you get out of wood door trim. It usually wicks water up from the bottom causing peeling near the base.........poor design flaw IMO. Also, most door trim (brick mold) is finger jointed wood and is prone to early paint failure. It's just one of those things you have to maintain every 2 or 3 years.
Alan, when you say "it's peeling", what does that mean? Where on the frame is it peeling? What is it peeling down to, bare wood or another paint layer? Gymschu stole my thunder, again. He's onto something about the base of the frames, which have a terrible track record for holding paint. Please be a little more specific with what, how, and where it's failing.
Great minds think alike. I believe it's twice in one day, if not mistaken.
If this is the third go around in 10 years I would be inclined to replace it. Get new trim, prime and paint ALL faces, including the inside face and especially the ends, before installing it. Oil primer and topcoat.
I think flaking is a better word for it and only in certain places but it will need to be redone.
Didn't see the word "directions" on label but I saw the word "wood" and under it it mentioned A-100 oil primer. Learn something new every day. |
Whats the best way to repair that? Pull the entire frame (or only piece with rot) and replace with full trim? I'm guessing about $200 for a job like that, am I right? |
ok , perhaps so, and I learned yet something else today. Life is harder when maintaining a home. But I noticed the white railing on front of house (southside) seems to be holding up well I think i did at least 2 coats on it. |
If it is indeed Brickmold, alan, you can replace it with PVC brickmold that won't rot and won't need painted.
| All times are GMT -4. The time now is 07:26 PM. |
