Paint Options For Garage Drywall With No Texture - Painting - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 08:46 PM   #1
Paint options for Garage drywall with no texture
Hi,
I'm planning to get drywall installed on walls and ceiling in the garage. About 1 1/2 of the wall is already drywalled because it's next to a living space. Drywall joints will be taped/mudded but there will be no texture applied. So, it will be probably a level 2/3 finish.
I'm leaning towards 1 coat of SW drywall primer and 2 coats of Superpaint for walls + Eminence for ceiling. Is that a good choice? Should I skip the primer, use a different primer or different type of paint etc?
Thanks in advance
twitter007 is offline   Reply With Quote
Old 06-11-2013, 08:57 PM   #2
Gymschu's Avatar
Rewards Points: 208
Excellent choices, go for it!
Old 06-13-2013, 09:23 PM   #3
Painting Contractor CT
Rewards Points: 77
Post
Your choices of paint are good, I would not skip the primer though.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 06-14-2013, 12:55 AM   #4
Thanks KD and Gymschu.
Old 06-14-2013, 01:53 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 816
It's a garage.....
One coat of primer....then I would suggest using a semi or high gloss exterior paint.
The only texture on my garage is what the heavy nap roller gave it.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
flashing paint due to drywall dust allaboutpaint Painting 7 04-17-2012 09:50 AM
How to paint drywall after patching? kennykenny Painting 10 01-27-2012 09:55 PM
Exterior Paint Options JBM Painting 2 12-14-2008 03:46 PM
How long should I wait to paint texture? bluefitness Painting 1 12-11-2008 12:51 PM
