-   -   Paint options for Garage drywall with no texture (http://www.diychatroom.com/f4/paint-options-garage-drywall-no-texture-181694/)
twitter007 06-11-2013 07:46 PM
Hi,
I'm planning to get drywall installed on walls and ceiling in the garage. About 1 1/2 of the wall is already drywalled because it's next to a living space. Drywall joints will be taped/mudded but there will be no texture applied. So, it will be probably a level 2/3 finish.
I'm leaning towards 1 coat of SW drywall primer and 2 coats of Superpaint for walls + Eminence for ceiling. Is that a good choice? Should I skip the primer, use a different primer or different type of paint etc?
Thanks in advance
Gymschu 06-11-2013 07:57 PM
Excellent choices, go for it!
KD PAINTING 06-13-2013 08:23 PM
Your choices of paint are good, I would not skip the primer though.
Good Luck!
twitter007 06-13-2013 11:55 PM
Thanks KD and Gymschu.
ddawg16 06-14-2013 12:53 AM
It's a garage.....
One coat of primer....then I would suggest using a semi or high gloss exterior paint.
The only texture on my garage is what the heavy nap roller gave it.
http://i43.photobucket.com/albums/e3...d/DSCN7363.jpg
