Old 09-18-2008, 03:04 PM   #1
Clueless and Alone
SweatEquitySux's Avatar
Send a message via AIM to SweatEquitySux Send a message via Yahoo to SweatEquitySux
Angry
Paint not sticking to wall
I've painted a lot of walls and never had this happen... It's like the surface (which has been painted perviously) is too smooth? If you go over an area that's dried a bit it just peels off and clumps up in other areas. I can also just peel it off like a skin after it's dry. What do I do to prep this type of surface??? Thanks!
SweatEquitySux is offline   Reply With Quote
Old 09-18-2008, 03:12 PM   #2
the Musigician
DangerMouse's Avatar
what brand of paint/how old is it?
"and they're off and running folks!"
DM
Old 09-18-2008, 03:23 PM   #3
Clueless and Alone
It's Behr (and yes I've read thru the thread, but I like behr paint, sorry) and I just bought it a couple weeks ago.
Old 09-18-2008, 04:44 PM   #4
What room is this? If it is a kitchen or bathroom, the surface needs to be well-scrubbed with a strong detergent and/or TSP, and then rinsed, before the application of new paint. A water-base bonding primer (NOT Kilz2) such as SW PrepRite ProBlock Latex can also be helpful.
For an existing glossy coat you must also scuff-sand and then remove the dust.
If the current coat is oil-base, you need to prime with an oil-base primer before topcoating with latex.
For now, remove all of your failing Behr paint before you do anything else...
SirWired
sirwired is offline   Reply With Quote
Old 09-18-2008, 06:23 PM   #5
Clueless and Alone
Thank you SirWired. It's just a little entry way and I don't know if it's oil based or not, it was painted by the previous owner. I will try the scruff sanding. All the other walls are textured and matte so I never ran into this before. Good thing I only payed $1 for the paint!
Old 09-18-2008, 07:46 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Test the previous paint to see if it's oil
Use denatured alcohol on a rag for the best test
It will dissolve latex and the color will transfer to the rag
Oops! or Goof Off! also work for this test
slickshift is offline   Reply With Quote
Old 09-18-2008, 10:53 PM   #7
Matthewt1970's Avatar
I would get your money back........
Sorry, I couldn't resist.
Old 09-20-2008, 02:15 AM   #8
Go down to any paint or hardware store and pick up a can of spray Kilz or BIN and spray an area and see if that sticks.
Old 09-20-2008, 04:49 AM   #9
paper hanger and painter
chrisn's Avatar
Maybe what happened to you might change your mind, it should.
chrisn is online now   Reply With Quote
Old 09-20-2008, 02:58 PM   #10
Ya know, after thinking about this I wonder if you have some grease on the walls or maybe even wax. The only other thing I can think of is the prevoius owner used silicone paint.
Old 09-20-2008, 05:09 PM   #11
slickshift's Avatar
Originally Posted by Matthewt1970
...the prevoius owner used silicone paint.
If the previous owner used oil-based paint, the latex could act like this
...grease on the walls or maybe even wax
If it was a bathroom, I'd say the walls were never cleaned properly
All that hair spray, deodorant spray, Glade and Febreeze, just gook up the walls
A Glade Plug-In (over a period of time) can contaminate a wall so it will do this also
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
How do I tape wall to keep paint from bleeding Thru? loomis56 Painting 5 04-19-2008 04:14 PM
Paint over pokey textured wall ekhochaa Painting 1 01-14-2008 08:18 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
