Paint Not Sticking In Bathroom - Painting - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 08:14 PM   #1
Paint not sticking in bathroom
Ugh. Please advise. I am trying to paint the bathroom. It looked to have had a glossy paint to begin with. I cleaned the walls, primed them, and waited 24 hours before applying my first rolls of a semi gloss paint that is not sticking. I'm not sure what to do now. I may not have applied the primer well enough; it was hard to tell bc it was white on white. I've read some things that make me think that I should sand things down and start from scratch with better priming. Any thoughts, suggestions? I have virtually no experience with painting.
Thanks!
Olivia
olivias is offline   Reply With Quote
Old 04-04-2011, 12:50 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Explain more what you mean by not sticking? Is it spider-webbing when you put it on? Is it pelling off or bubbling?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-04-2011, 01:12 AM   #3
The paint just sort of smeared around on the wall as I rolled it on; I guess it was bubbly rather than solid and smooth. It was easy to notice bc this layer is a greenish color, where as the primer is white. I tried to roll back over areas that didn't seem to be taking, but there were areas where the paint was just not going to stick . It just smeared around, with areas of white primer showing through. Hope that makes sense. I'd appreciate any help.
Old 04-04-2011, 03:47 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
How long did you let the primer dry and what did you clean with. More information would be helpful.Type of primer, paint, etc.
Old 04-04-2011, 04:32 AM   #5
"smeared around"
Sounds to me like your roller handle isn't working properly or you may be pressing it too hard against the wall. It's dry now, do a tape test. Press some tape on and rip it off. If the paint dosen't come off on the tape your good.
Buy a new roller handle, a 3/8 in roller cover, and don't soak the roller cover.
Old 04-04-2011, 07:52 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
What is the brand of paint that you are using? sounds a bit like it's not covering more than it's not sticking. A poor quality paint will not cover as well, and it sounds also like your technique as explained above.
Brushjockey is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Questions about Sherwin Williams paint for a bathroom nitting Painting 2 03-28-2011 05:23 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Bathroom paint dilema JamesTee Painting 8 02-03-2011 09:46 AM
Choosing paint for bathroom CowboyAndy Painting 3 04-04-2008 05:49 AM
