To Paint Or Not To Paint: The Metal Chimney Cap? - Painting - DIY Chatroom Home Improvement Forum
Old 07-23-2009, 05:04 PM   #1
Rewards Points: 200
To paint or not to paint: the metal chimney cap?
Dear all:
For "good looking" reasons, we are thinking of painting our newly replaced metal chimney (or chimney cap) and vent (and flashing maybe) on the roof. In general is this a good idea? Why and why not? If it is a good idea, what kind of paint should we be using? Thanks!
By the way by painting it, would it make the metal chimney cap more durable and could last longer (preventing rust)? If the fireplace is being used, I would assume that the chimney cap could get very hot, would this become a problem for the paint? Thanks again!
ohman is offline   Reply With Quote
Old 07-23-2009, 05:06 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
A can of spray paint will be fine. They are usually a good oil based enamel.
Old 07-23-2009, 06:39 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
if its aluminum ,stainless or copper i wouldn't paint ,it becomes a maintenance problem,if its galvanized i would paint before it starts rusting,or replace it with a more durable material
Tom Struble is offline   Reply With Quote
Old 07-24-2009, 07:35 AM   #4
NAV
yea, it depends on the metal it is made out of. I would assume its galvanized.
The heat will be a problem.
NAV is offline   Reply With Quote
Old 07-25-2009, 07:44 PM   #5
100 Year Family Tradition
4ThGeneration's Avatar
DTM makes a HR(Heat resistant) coating you can use on the chimney cap. If it has rust on it you can use steel wool, but also treat with an oxolic acid or some ospho prior to painting.
4ThGeneration is offline   Reply With Quote
Old 08-12-2009, 12:00 AM   #6
Weather will eventually wear the paint off. I install fireplaces for a company and we paint caps and term caps all the time. They last awhile but like mentioned previously, it becomes a maintenance issue but could keep it from rusting if properly maintained. All our handmade covers are gavalume but our custom shop covers are made from metal with a bonded finish.
ausblake is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Powder or Liquid Paint Nestor_Kelebay General DIY Discussions 2 01-06-2009 06:05 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
