Paint New Wood Entry Door - Painting - DIY Chatroom Home Improvement Forum
Old 10-17-2008, 07:45 PM   #1
Unhappy
paint new wood entry door
I've got a now Mahagany wood entry door, unfinished. My questions are:
What kind of paint I should use,
how many coatings on each steps,
How to do it?
Thanks!
manwork is offline   Reply With Quote
Old 10-18-2008, 12:20 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
If it has a beautiful wood grain then have it maybe stained and polyurethane or just polyurethane. If not and you can take it off the hinges for a few days or just leave it open for a few days, then a coat of good oil based primer and then oil based semi-gloss would be the best most durable finish You can get some Japan-Drier to make oil based paint dry quicker. If you can't leave it open or off the hinges, get some Zinsser Cover Stain which is a good quick drying oil based primer and some Benjamin Moore MoreGlo or Sherwin Williams equivalent Semi-Gloss latex but I would still recommend leaving it open overnight to keep it from sticking to the frame and pulling off the paint. One coat of Primer and one coat of paint will do it provided you have the same color.
Old 10-18-2008, 08:21 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
I agree that an oil based stain will give you the best results. If this is a new prehung door you should be able to remove the weather stripping that runs around the door jamb. It should just pull out with moderate effort and can be replaced when the door is dry using just your fingers, but possibly may need to utilize a screwdriver or '5-1' paint tool. This should allow you to shut the door before the stain/paint is totally dry. Pulling the hinge pins and laying it flat will give you the best results, especially if you are planning on using a polyurethane. A mahogany door is very heavy and would be best removed and replaced by two people. If you opt to stain it in place just be sure to protect your floors with some plastic sheeting or even a large trash bag.
Man of many hats
wrangler is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Repairing wood siding next to a door frame... Beth777 General DIY Discussions 7 07-22-2008 08:56 AM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
