Old 03-06-2013, 11:05 AM   #1
paint masking
I'm looking at buying a paint sprayer to save time, but it sounds like you have to mask off everything to prevent over spray. is there any product out there that helps with the masking job to make it go quicker? Seems like the time you save in painting would be taken up in masking and clean-up
don scott is offline   Reply With Quote
Old 03-06-2013, 11:10 AM   #2
paint masking
And you would be right.
Stick with a 2-1/2 sash brush and a 1/2 nap roller.
Do not cheap out and by a cheap brush, roller covers, or paint. Go to a real paint store for the materaisl and for great advice, not a box store.
Old 03-06-2013, 11:47 AM   #3
paint masking
Absolutely It's called a hand masker you can get it at Sherwin Williams as a kit so it comes with the cutter and rolls of plastic. It cuts masking time by at least half.
Old 03-06-2013, 12:01 PM   #4
paint masking
Never once have I seen any pro painter using tape when painting trim.
1/2 the time it ends up rpping off some of the paint.
Old 03-06-2013, 12:08 PM   #5
paint masking
Hiya Don,
Just be aware that sprayers aren't always the time savers you may think - there is a whole lot more preparation involved than when painting with a brush and roller - and additional drops and masking supplies, coupled with the extra amount of clean-up time, may prove to be more costly in the long run (not to mention the maintenance and amount of time it takes to clean a sprayer in between jobs).
What type of spraying are you considering? Interiors? Exteriors? Wood finishing? If you're considering a hand-held "buzz" gun, I think you're kinda wasting your time and money. For walls and exterior work, a 1/2 gpm airless will work great, but is also capable of making a tremendous mess...An HVLP unit is great for wood & fine finishing, but really doesn't save a whole lot of time versus a brush (especially when you factor in add'l masking, drops, and sprayer clean-up). Whatever you decide, practice - practice - practice, before committing to spraying any job or project.
To answer your question about masking, ToolSeeker mentioned the hand masker - and they are great time-saving tools. Personally I prefer to use masking paper in mine, instead of plastic, but that's a "to each his own" thing... and ALWAYS, ALWAYS use a high quality masking tape - ALWAYS. "Blue" tapes are extremely popular now 'cause the adhesives used does not require immediate removal of tape, but unfortunately not all blue tapes are created equal. It won't save you any money to go with a cheap tape that either doesn't stick well enough, or doesn't release when you need it to. Personally I use 1" frog tape in my hand masker with great results.
ric knows paint is offline   Reply With Quote
The Following 2 Users Say Thank You to ric knows paint For This Useful Post:
Gymschu (03-06-2013), ToolSeeker (03-06-2013)
Old 03-06-2013, 03:21 PM   #6
Gymschu's Avatar
paint masking
Ric, your post about spraying should be a "sticky". I would venture to say that threads about spraying are #1 here in the painting forum.
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Repairing where paint peeled off with masking tape? Doug Crf Painting 4 04-29-2006 11:47 PM
