Paint Lifting Off Of Moulding - Painting - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 08:50 PM   #1
Unhappy
Paint Lifting off of Moulding
Had an extensive closet addition built in a room that required replacement molding, toe molding. Original molding, toe molding was removed, cut to fit outside openings, refinished and was the hammered back in place after all painting was completed. All painted woodwork was palm sanded, hand sanded, primed and 2 coats of interior latex paint. The molding had previously been painted but originally was natural years ago with I guess a shellac on top. I have now discovered that the new paint and and all old paint underneath is now lifting in some spots (like paper flying in the wind)! I think the friction from hammering the toe molding back in place jarred all of what was ever there.
I haven't even started the rug, curtain crap yet. Now What? Is there a easy fix without having to strip this down. I ran caulk along all molding where it met the wall before priming and painting.
Any suggestions would be appreciated. Sorry for the long drawn out description. I'm new.
tdrunner is offline   Reply With Quote
Old 01-09-2012, 09:03 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Buy new "toe moulding". Painting over shellac (even though you sanded it) can be kind of difficult.
Can't you "hammer" on it with a little finesse and a nail set?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
tdrunner (01-10-2012)
Old 01-10-2012, 04:13 PM   #3
Rewards Points: 77
So, if i primed and then painted over quarter round that had a wood finish it will eventually start peeling up? I have a room that i need to paint that has white baseboards with quarter round that has a wood finish. Need to change the quarter round to white.
asbury park is offline   Reply With Quote
Old 01-10-2012, 08:27 PM   #4
Unhappy
I failed to say that the moulding the paint is coming off of isn't the toe moulding. It's the base moulding that was never removed. The toe moulding isn't painted and never was. That is what was removed and put back on. Since the floor is hardwood and I could get the rest of it off, I did so it would be easier to remove all the years of dirt, grime, sand and repoly. It came up really nice! Had I have know this was going to happen, I would have cleaned it up carefully without removing it. Some of these houses don't even have the toe moulding anymore. Even though this house was wall-wall carpet at one time, it was never totally removed.
All of the other rooms I've repainted the base moulding and never had this happen before BUT none of the toe moulding had ever been removed and put back either. All the wood work in this house was natural at one time. Way before I ever lived here it was all painted over. What a stupid decision.
Old 01-10-2012, 08:32 PM   #5
With what happened to me, I would sand and paint what you have and not remove and replace unless you replace the base too. I'm assuming when you say quarter round you mean toe or shoe moulding.
Old 01-10-2012, 08:44 PM   #6
Lightly etc quarter rd. with 220 grit or so sandpaper to scuff it up.Use a good quaility stainblocking bond coat primer like zinsser primecoat 2 or similar primer and then apply topcoat of your choice.Make sure to clean trim prior to sanding and dust removal after sanding also.
mudbone is offline   Reply With Quote
Old 01-10-2012, 08:50 PM   #7
YOu could use an air finishing nailer help reduce hammer shock.
Old 01-10-2012, 10:38 PM   #8
I wish I had something useful to say on this subject, that is super frustrating! Sorry to hear that, I am interested in knowing what you ended up doing
PaintingTech is offline   Reply With Quote
Old 01-11-2012, 03:44 PM   #9
Smile
Paint Lifing off of Moulding
I couldn't keep my mitts off of it so I "peeled" some off last night at 10:00 to the point that I now have to fix it. My way of making sure it gets done right. I plan on scraping off what I can, resanding and will prime and paint it again. At least right now it's only 2 pieces of base moudling this is hapening to. I'll report back as to the progress. Might be a week or 2.
Thanks to all!
Hardwood floors - moulding and paint question sayitaintso Flooring 0 11-19-2010 06:35 AM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
