Paint That Lasts????????? - Painting - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 01:28 PM   #1
paint that lasts?????????
is there any paint that last for 30 years out doors
Sinclair6 is offline   Reply With Quote
Old 07-19-2012, 01:36 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-19-2012, 03:56 PM   #3
Gymschu's Avatar
Rewards Points: 244
Sinclair what you be smoking'? LOL. No, no paint lasts for 30 years which is about as long as I have been a painter. I do have a restaurant I painted in 1978 that still has the original paint on it. It was a cinder block building that I put block filler on and painted brown. It's looking pretty rough. I have seen paint jobs last a good 10 - 12 years IF the surface being painted was not in direct sunlight or exposed too much to the elements. Some aluminum sided paint jobs last 12 - 15 years before needing repainted.
Old 07-19-2012, 04:55 PM   #4
Phil - "the Paint Guy"
Define "lasts"
Cpcphil is offline   Reply With Quote
Old 07-19-2012, 05:17 PM   #5
Rewards Points: 12,882
Vinyl siding it if you do not want to paint.
Old 07-19-2012, 05:42 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
maybe if it stays in the can un opened maybe
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
DangerMouse (07-19-2012)
Old 07-19-2012, 06:32 PM   #7
Gymschu's Avatar
Rewards Points: 244
Joe, well stated........vinyl is final......well, sort of. I've seen taupe vinyl siding fade to nearly white after a year. Vinyl oxidizes just like any other surface although keeping it cleaned every year or so sure helps. I have painted a few of the "Vinyl is final" homes over the years and I'm sure there is more to come.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 07-20-2012, 11:35 AM   #8
Too Short? Cut it Again!
Nothing can diminish the value of a wood sided home faster than covering it with vinyl because you believe the hype you will never have to paint again. Maybe true but as mentioned, vinyl fades fast and the cheap stuff turns brittle. It is hardly the low maintenance siding material it claims to be.
The Following 2 Users Say Thank You to user1007 For This Useful Post:
chrisn (07-20-2012), Gymschu (07-20-2012)
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
