Paint For Kitchen - Painting - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 05:25 PM   #1
Rewards Points: 115
Paint for kitchen
I'm redoing my Moms kitchen, she does alot of cooking. What type of paint can I use that won't be such a magnet for grease?
Thanks in advance!
Carloscda is offline   Reply With Quote
Old 10-16-2012, 05:33 PM   #2
Rewards Points: 13,300
No paint is going to repel grease. Just use a quailty paint store paint with a higher gloss so it's scrubable.
Installing or running a fan over the stove that exhaust outside not just recycles the air would sure help.
Old 10-17-2012, 10:43 AM   #3
Aura Kitchen & Bath is supposed to be very scrubable even in flatter sheens, if you're not ok with the shiny stuff.
MEE123 is offline   Reply With Quote
Old 10-17-2012, 02:58 PM   #4
Too Short? Cut it Again!
Aura is pretty amazing stuff and even the flat is extremely washable. Acrylic semi-gloss or even gloss in lighter shades is common for cabinets. Just make sure you are using paint store and not box store paint. Make sure to apply two coats to get a good thickness and prime really clean and prepped surfaces of course. No kitchen finishes are going to look like much or hold up for long if you are not intent on getting all the grease off to start.
Although Melamine paint was originally designed for painting over laminates it hovers around being almost popular for general kitchen cabinets where a durable high gloss finish is desired. It is high gloss and very washable. Its drawbacks are that it is a bit hard to apply and it tends to chip.
Old 10-19-2012, 10:11 PM   #5
Rewards Points: 5,974
I have used oil based quite a bit in kitchens for the very reasons stated here the washability and I have always used a semi or gloss. I have never used the paint recommend here in a kitchen but if these other guys have it seems like a good alternative to the odor and mess of oil base.
Old 10-23-2012, 01:00 PM   #6
White-colored is still the most popular paint color choice for your kitchen, according to Kitchen Designer Ideas. Simply white surfaces let the cabinets, kitchen counter and flooring stand out in region area.
Polmki is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 05:46 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
