Paint Keeps Peeling - Painting - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 12:16 PM   #1
Paint keeps peeling
Scrapped popcorn ceiling off and attempting to paint with latex paint. Now, when applying a second coat of paint, the first coat peels off.
jbaker1948 is offline   Reply With Quote
Old 07-16-2012, 12:22 PM   #2
Rewards Points: 13,694
Did you sand, wipe it all down with a damp cloth, and use a primer before the paint?
Gymschu (07-16-2012)
Old 07-16-2012, 07:56 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
Good points Joe C.... Did you wait between coats to allow the paint to dry? Recoating too early will re-wet the first coat and cause it to lift from the surface but i think that i will agree with the surface prep with this one. If you are waiting between coats then take a sample of the dry paint that has peeled off and look at the back of it for drywall dust. If you find evidence of dust or dirt then you should clean as joe said and probably use a bonding primer. I'm not a house painter so i can't suggest a specific product.
mustangmike3789 is offline   Reply With Quote
Old 07-16-2012, 08:30 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
After scraping off texture- I always prime - with either Zinnser Gardz or a good boning primer. The mud in texture is not very strong and the paint will cause it to let go- Gardz will penetrate and seal.
Very often I am skimcoating a ceiling too so that usually bonds well to the previous mud, but I will even prime first then.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (07-17-2012)
Old 07-17-2012, 04:00 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
i would bet NO
The Following User Says Thank You to chrisn For This Useful Post:
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
