Paint And Grain? - Painting - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 11:40 AM   #1
Amanda-Knox's Avatar
Question
Paint and grain?
I'm wanting to do paint & grain on a couple of cupboards that are currently glossed. Would the following plan work?;
Electric sander, primer, then paint and grain? Xx
Amanda-Knox is offline   Reply With Quote
Old 04-18-2011, 08:36 AM   #2
Rewards Points: 258
Hey Amanda,
Before you begin sanding I would suggest you wash the cupboards first using TSP. Secondly, when you say prime...what primer do you plan to use?
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 04-18-2011, 08:41 AM   #3
Originally Posted by spraygunn View Post
Hey Amanda,
Thanyou, I shall buy some terps to get started then!
Going to struggle with the detailed parts of the door with the sander though I think.
I'm not sure what primer it is that I've got, just a tin of white primer that I bought to paint a plastic coated chest of drawers so I could change the colour.
Old 04-18-2011, 08:59 AM   #4
If you use TSP be sure to rinse well with clear water. As to the sanding, you don't need to get too far into the detail. The proper bonding primer will handle the adhesion in those areas. The idea of light sanding is to smooth the surface somewhat and further support the bonding primer. Since you purchased it to paint what you did, it probably has a bonding quality. Check the label to confirm. If it's not a bonder, you need to increase the sanding effort or buy a specific bonding primer.
Old 04-18-2011, 09:03 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Do the back side of one door as test............
tcleve4911 is offline   Reply With Quote
Old 04-18-2011, 09:15 AM   #6
Thank you all for your help, made a step by step list from what you've all told me and I think I know what I'm doing now!
Do I need any specialty stuff to take the terps off so it doesn't affect the primer going on?
Old 04-18-2011, 10:14 AM   #7
If by terps you mean turps or turpentine (technically not the same thing), I would suggest not using that as a cleaner. They are both good degreasers but could leave an oily residue on the surface. As degreasers, they're generally used on things not intended for painting. I will generally use paint thinner as a spot degreaser, but never as a whole cabinet system cleaner. There are a number of cleaners designed for paintable surfaces such as TSP and Dirtex and KrudKutter to name a few. They're safer to use and easier on the body. Keep it simple.
Old 04-18-2011, 10:18 AM   #8
Excellent, thankyou!
I shall get some TSP and just wipe it down with a damp cloth when finished then. Xx
Old 04-18-2011, 03:00 PM   #9
Rewards Points: 258
Amanda,
Trisodium phosphate http://en.wikipedia.org/wiki/Trisodium_phosphate Turps is what the old timers used to call paint thinner......an oil by-product.
Never thought you'd get so much help, did ya?
Best of Luck
Steve
Old 04-21-2011, 11:29 AM   #10
Thankyou for your help
Spoke to people at a couple of DIY stores too and combined with your advise, looks like I may have a plan of action, please tell me what you think!
*Chip off loose gloss from surface (it's coming away quite easily)
*Go over surface with TSP
*Remove doors as the the hinges have gloss all over them and should be replaced
*Fill in any chips with wood filler
*Once over with the electric sander
*Dust down thoroughly
*Apply ESP primer
*Use paint and grain
*Put doors back on new hinges when dry
Old 04-21-2011, 11:40 AM   #11
Rewards Points: 258
Hi Amanda,
Sounds very general, but that sounds good.
Best of Luck
Steve
Old 04-21-2011, 02:22 PM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 602
Rinse, rinse and then rinse again that TSP, then rinse it again with clean water or you will have a disaster on you're hands.
Old 04-21-2011, 09:43 PM   #13
ESP primer?????
Old 04-22-2011, 06:09 AM   #14
I'm now thinking of just missing out the TSP, the surface doesn't look that difficult once the thick gloss is peeled away.
ESP (easy surface primer) is apparently the strongest primer on the market, it sticks to just about any smooth surface and creates a rough paint finish (a bit like dry wall) so paint can be applied on top.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Painting Bookshelves - what type of paint? justin2009 Painting 9 01-05-2009 09:18 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Paint recommendations and finish questions EJacobs Painting 2 09-03-2008 10:38 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
