Paint For Garage Door - Painting - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 05:03 PM   #1
paint for garage door
Hi,
I have two steel garage doors which were originally white and painted with brown when the house was redone. The doors are on the southeast side of the house so they get more than half of the sun during the day.
By now the paint has started flaking off and I hope to get them redone this summer.
My question(s):
  • Should I prime the doors after I scrape and brush them? If so, what should I use? Rust-o-leum?
  • What kind of paint works best in this situation? Oil or latex? I know the advantages of using latex but I want this to be a one time deal that lasts a while.
  • A particular finish work best?
frumdogg is offline   Reply With Quote
Old 06-12-2012, 06:22 PM   #2
Rewards Points: 13,300
Any metal door should have had acrilic latex.
If it's in the sun it would be far better to pick a lighter color.
Old 06-12-2012, 10:21 PM   #3
Gymschu's Avatar
Rewards Points: 492
With steel doors I like to play it safe and use oil-based paint. Latex can be used but there's a higher risk of producing rust from the water in the latex. Scrape and wire brush all the loose paint off. You can spot prime with a rusty metal primer and then apply one or two coats of Rustoleum or a Direct to Metal paint. Keep in mind that the oil based paints will produce a high gloss finish.
Gymschu is online now   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
exterior front door painting after builder paint m1951mm Painting 9 08-20-2011 09:20 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
