Paint And Fixing Masonite Siding - Painting - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 11:08 AM   #1
Paint and Fixing Masonite Siding
Hello All,
About to paint my house which has masonite siding...there are some really bad areas which I will replace. However, there are lots of areas where the siding is just ruffled at the edges...
I'm planning to scape the ruffles off but not sure whats the best material to use to seal it before I paint
I want something that would last....what is better than caulking...any suggestions
thanks
iwannafish is offline   Reply With Quote
Old 12-03-2013, 11:16 AM   #2
Rewards Points: 394
If masonite siding has deteriorated and the plies have come apart ("ruffles"?) it is probably best to replace it. The plies are held together with sawdust, and wax, which leach out when the siding is aged. For painting, a full prime with an alkyd exterior primer, followed by an acrylic topcoat should be fine.
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
Gymschu (12-03-2013)
Old 12-03-2013, 11:41 AM   #3
thanks....I cant afford to replace all the siding...looking for a an alternative to make it last another 5 year ...
the ruffling is very small along the edges....was hoping there is way to seal it before painting...
the bad sections, I'm planning to replace...
Old 12-03-2013, 12:18 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
When we were called out to repair that type of siding, we would cut the siding off at the bottom just high enough to install a 1X12 with a drip cap on top of the 1X12. Usually that is where the damage was or that is where the damage starts. When we installed a 1X12 we always sealed the raw edge of the siding or it would not last long.
If the siding is bad higher than a 1X12 will fix, you can still fix it but it won't look as good. Cut the siding where there is good material, install a Z flashing and install new siding below. Chances are you will not be able to match the siding there now but the looks are up to you if you can tolerate it not. JMHO
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
How best to paint a derelict, poorly prepped garage? a-dogg Painting 34 05-21-2013 07:56 AM
Painting my Aluminum and Vinyl Siding rayf01 Painting 2 05-11-2012 08:58 PM
HELP - fixing a bad paint job Marietay Painting 1 03-22-2010 02:50 AM
Fixing my Red Paint omarelgrillo Painting 16 02-12-2009 10:48 PM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-18-2007 11:26 PM
