Paint Exterier - Painting - DIY Chatroom Home Improvement Forum
Old 05-11-2009, 05:07 PM   #1
Paint exterier
Just installed cedar siding on a new addition. Do I need to do any prep work before I stain it?
Davidb6 is offline   Reply With Quote
Old 05-11-2009, 07:08 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Just make sure it's clean of any debris or contaminants, sand off (rough up) any mill glaze, and oil prime if tannin bleed may be an issue (certain red cedars)
Your siding supplier should also supply any details
slickshift is offline   Reply With Quote
Old 05-12-2009, 11:18 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Use an oil based stain. It is relatively unaffected by wood tannins that will cause paint bleed.
Old 05-12-2009, 04:56 PM   #4
It's been raining a lot here...how long should I wait after it rains to paint? Want to make sure the shingles are good and dry.
I assume damp shingles react the same to paint as they do stain?
Old 05-12-2009, 05:12 PM   #5
The next day is usually fine. Start by doing one board at a time and you will see if it is reacting to being too moist.
Old 05-12-2009, 11:34 PM   #6
I would give it one day of drying then it should be o.k.
waynech is offline   Reply With Quote
Old 05-14-2009, 09:03 AM   #7
Thanks for the help!
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
