Paint Easy To Peel Off - Painting - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 01:21 AM   #1
Paint easy to peel off
I recently hired a contractor to paint an old apartment. The problem is that when I scratch the paint, it comes off easily and then I could start peeling it in sheets... The new paint that they're using is acrylic latex statin. Also, underneath the paint is a little chalky, dont know if thats normal. Any idea whats wrong? Thanks
mikeeee is offline   Reply With Quote
Old 03-20-2010, 02:43 AM   #2
Finisher
Hello again Mikeee
As I stated on PT, your problem is most likely a cheap latex over an oil coat. Improper prep and lack of priming as well.
Rcon is offline   Reply With Quote
Old 03-20-2010, 10:24 PM   #3
I think you should just paint it yourself! May want to do more than one layer though, just in case
VenusHalo35000R is offline   Reply With Quote
Old 03-22-2010, 10:49 PM   #4
What I did
I used a scrapper to peel off what would peel. then sanded the wall with orbital sander.Then clean the wall. Then primed wall. Then fixed imperfections. then primed again.Then painted to coats!This was on a 1955 plaster wall. Very poorly Painted glossy over dirty wall,and who knows what else.The painting is easy If it's your house the time will be worth it. Butter
butter is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 01:25 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Oil, Latex, Acrylic... How to Choose? Turkmenbashy Painting 4 01-18-2009 12:30 PM
