Paint Drywall Under Tile??? - Painting - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 10:40 AM   #1
Rewards Points: 676
Paint drywall under tile???
I've got the new bathtub surround complete with 5 foot Durock around the tub and then sheetrock above it and to the outside of the tub. Outside being the tub is in an alcove that comes out 4 inches beyond the tub and then is in about 1 ft from each wall.
We are getting ready to prime and paint before doing the tile. Do I prime or not prime the drywall that will have tile on it? What about where I had to mud near the metal corner bead?
B
Beepster is offline   Reply With Quote
Old 03-07-2013, 11:40 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
It's good to prime it. And I assume your mudded area is getting painted- yes, certainly prime it.
Don't prime the Durock.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-07-2013, 01:58 PM   #3
Rewards Points: 676
I am tiling up to the metal/paper corner bead on the tub side. I mudded each side of the corner bead to make it smooth. Do I prime the tub side of the corner bead that was mudded and will be tiled over?
B
Old 03-07-2013, 02:37 PM   #4
I would think yes, but you really should be asking your tile guy what he wants. Or are you also doing the tile?
Old 03-07-2013, 04:11 PM   #5
Rewards Points: 676
I am my own tile guy. I will post in the tiling section if I don't get an answer here.
B
Old 03-07-2013, 04:18 PM   #6
DIY staff
Rewards Points: 7,174
Yep---as long as you have the brush and roller out---prime the drywall---no harm if you don't
but it couldn't hurt---
As Brushjocky said---don't prime the Durrock----
Old 03-07-2013, 04:28 PM   #7
Main thing you want to think about is what will help the tile mastic stick. It will stick better to a prime ( that is well adhered..) than to straight mud. Durock is a perfect substrate for tile mastic- no need to do anything.
The Following User Says Thank You to Brushjockey For This Useful Post:
oh'mike (03-07-2013)
Old 03-08-2013, 08:17 AM   #8
Rewards Points: 676
That's what I was looking to hear. I will go ahead and prime the drywall.
Thanks.
B
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Peeling Paint To Drywall angelatc Drywall & Plaster 4 09-07-2012 10:52 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
