Old 05-05-2009, 08:56 PM   #1
Default Paint Crown Molding Before or After Installation?
Painting interior and installing new crown molding (walls are one color, ceiling and crown molding another). Is it better to paint the walls, cut molding to measure, paint new crown molding, install crown molding, touch up; or is it better to install the crown molding, paint ceiling and crown molding, tape, paint walls.
I imagine there will be caulking involved at some point that will need to be painted one of the two colors at the edge of the two-tone paint transition?
gmhut is offline   Reply With Quote
Old 05-06-2009, 11:00 AM   #2
Paint the walls and ceiling. Prime and paint the crown before you install it. I always paint before I cut and fit molding. Once you have it up it often only takes a little caulking to finish it up.
Rege
RegeSullivan is offline   Reply With Quote
Old 05-06-2009, 06:49 PM   #3
Every "how too" article I've read strongly suggests using a coping saw for one of the pieces when fitting the corners. This seems like a time consuming pain, although I've never done it, so maybe it's faster and easier than I imagine it to be.
How important is using a coping saw to cut the matching profile of one end of a piece butted to the uncut end of another vs. just cutting each piece at a 45 degree angle with a chop saw?
Do most professionals use the coping method as the articles I've read suggest, or is that not as prevalent as the "how to" articles seem to imply?
Does using the coping method impact the "paint before cutting" method as far as marring the paint around the coped cut?
Is the priming on pre-primed molding from HD enough, or should I prime it myself anyway?
Old 05-06-2009, 08:46 PM   #4
Learning by Doing
Leah Frances's Avatar
I am just this week learning how to do this sort of stuff. Here's my $.02:
- Prime, but don't paint before installation - you're going to have to paint after you caulk anyway.
- Coping is WAY easier than you think. Get a coping saw and go for it. I found it much easier if I clamped the molding within 6 inches of the end being coped. My first few weren't picture perfect (I chose less visibly conspicuous corners for my novice attempts). By my third or fourth it was fairly quick and easy.
Give it a go!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-06-2009, 11:11 PM   #5
The seasonal changes really show an open miter, but not so much a coped, because of the area of end grain when they shrink opposed to a thin line on coped.
Check out the homemade tool: http://www.taunton.com/finehomebuild...echniques.aspx
And complex: http://books.google.com/books?id=7XU...crown+moulding Be safe, G
GBR in WA is offline   Reply With Quote
Old 05-07-2009, 04:46 AM   #6
Crown, casings, base, and doors are in progress right now on our remodel. Here is what is working out really well for me. Pre-primed MDF moldings, pre-paint with SW waterborne enamel, install, caulk, minimal touch-up needed. The pictures are before touch-up.
paint-crown-molding-before-after-installation-dscn0912.jpg   paint-crown-molding-before-after-installation-dscn0909.jpg
Old 05-07-2009, 06:52 AM   #7
paper hanger, painter
chrisn's Avatar
Send a message via Yahoo to chrisn
Looks good from here. Personally, I would prime first and do the finish coat(s) after nailing and caulking.
Old 05-07-2009, 01:24 PM   #8
Default Paint Before you Install
It's always a good idea to paint your ceiling, walls and crown molding before you install it. This way you don't have to try to paint around the various components. After you paint everything separately and install it you are done.
TJ
TJLoop is offline   Reply With Quote
Old 05-07-2009, 02:47 PM   #9
Coping helps to disguise the joints better as they expand and contract with the changing seasons. If you perform a simple chop, the gap between the pieces will be twice as large, and probably too big to reliably bridge with caulk.
SirWired
sirwired is offline   Reply With Quote
Old 05-10-2009, 09:15 PM   #10
Household Handyman
I'm sure I'm "old school" but I learned under my Grandad and now I'm 60. I have friends who do trim carpentry who are my elders. One thing I have learned is to prime and paint crown and base before even starting the project.I believe it makes things go easier in the long run,just a little touch-up. As far as coping, it's the only way to go for me. Thanks, David
Old 05-10-2009, 09:48 PM   #11
TJ
I have never painted a ceiling or wall before I put it in
Generally if you have nice true walls and ceiling then you can paint the trim before putting it up. If you forsee a lot of caulking, prime it first, then paint it after it is up.
Old 05-11-2009, 12:46 AM   #12
For some reason I just assumed you caulked the edges automatically. Is it the case that you only caulk if the walls are wavy enough to need cosmetic surgery at the with a calk gun?
Old 05-11-2009, 12:25 PM   #13
I have never been lucky enough to have 4 walls in a room not need to be caulked with painted trim. Even casing which tends to pull tight to the wall can use a little caulk to fill in gaps most of the time. I have installed stained trim that looked pretty good but I ended up taping the trim and filling in with caulk and it looked even better...
Rege
Old 05-11-2009, 01:25 PM   #14
The thing about caulking is that if you caulk after it has been painted, dirt will penetrate the caulk a lot more than the painted trim so it will discolor. Same goes for smoke if you are a smoker. If you have painted over the caulk it won't do that.
Old 05-13-2009, 12:57 PM   #15
1. Pre-prime and paint your trim (not required, but saves time in the long run)
2. Absolutely cope your joints. Don't even consider not doing it.
3. Spackle and sand nail holes. Prime the spackle if your paint calls for it. Caulk all seams.
4. Paint ceiling
5. Paint an entire coat on your crown (don't skimp by just trying to touch up caulk and spackle)
6. Paint your walls
cej22 is offline   Reply With Quote
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cope crown on an inside corner. The reason that you might cope crown molding, is that sometimes your walls maybe out a little bit, your angle... Read More »
After you've taken all of your measurements, you need to mark and cut your base moldings. You must account for all doorways and corners before you start cutting. Properly cut baseboards create a nice, clean accent to your room. Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we will be demonstrating how to cope a base on a 90 degrees corner with a miter saw and a coping saw. When you are coping in base, it really allows you to get a super tight corner... Read More »
In order to install base molding, you must be familiar with inside and outside corners. Inside corners and outside corners cut totally opposite from each other. In the steps below, you'll see how to manage the cutting of inside corners. Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 06:57 AM
Crown Molding Paint Finish Desperate Housewife Painting 5 11-13-2008 01:04 AM
Flashing NoExperience Painting 13 09-04-2008 07:56 AM
Flat over Semi-Gloss dankreboot Painting 10 07-06-2008 12:28 AM
Blotchy crown molding paint lewlewjones Painting 7 05-13-2007 05:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
