Paint Cracking - Painting - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 03:29 PM   #1
Red face
Paint cracking
i PAINTED MY HOUSE APPROXIMATELY 4 MONTHS AGO. I HAD TROUBLE BEFORE WITH THE PAINT FROM lOWE'S SO THIS TIME WENT TO sHERWIN WILLIAMS AND TOLD THEM OF PROBLEM THAT PAINT WAS CRACKING EVEN WITH NEW PAINT. i SANDED ALL THE WALLS. thE Y GAVE ME PAINT THEY SAID IT WOULDN'T HAPPEN ANYMORE. 4 MONTHS LATER IS HAPPENING AGAIN. cAN ANYONE GIVE ME ADVICE WITH THIS PROBLEM.
hOUSE HAS RADIANT CEILING HEAT.
THANKS
sylviamr is offline   Reply With Quote
Old 01-30-2013, 03:58 PM   #2
What walls are they, is the outside on the other side of them? Is it the top or bottom of the walls, or throughout? Has this been an issue for as long as you owned the house? Try to give a bit more info.
Old 01-30-2013, 05:56 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Was there wallpaper before you painted?
chrisn is online now   Reply With Quote
Old 01-30-2013, 06:51 PM   #4
Gymschu's Avatar
Rewards Points: 218
Were walls prepped properly? Did you sand and remove dust from the walls before priming? You did prime with a quality drywall primer? Apply 2 coats? Millions of variables here and we need more info to help you. Adding a pic of the problem really helps also.
Old 01-30-2013, 10:53 PM   #5
Rewards Points: 626
first off you have your cap lock on. second what did you do for prep work? what is the substarit you are painting? where is it cracking? on the taped seams? nail pops? what? a photo is worth so much to help us help you.
Nailbags is offline   Reply With Quote
Old 01-31-2013, 02:30 PM   #6
Rewards Points: 101
If it is on exterior walls, could be too much moisture from the inside of the house. Same in vice-versa. I'd say to check for moisture problems.
mt999999 is offline   Reply With Quote
Old 01-31-2013, 03:11 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
THANKS
That might be the problem.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 01-31-2013, 03:45 PM   #8
That's the first thing that crossed my mind Matt. I've seen it before firsthand and we just discussed it here a few weeks back. But, the problem is only ever with ceilings, not walls, that I've ever seen or heard. That's why I asked if it was the top of the walls, where it might be possible that the heat coming off the ceiling is affecting them.
Old 01-31-2013, 04:41 PM   #9
Rewards Points: 12,830
I bet the person that came up with RADIANT CEILING HEAT is the same person that came up with partical board, Masonite siding, quest tubing, Cellotex, and orangeberg pipe.
Heat rises, why put it in a ceiling?
Gymschu (01-31-2013)
Old 02-01-2013, 12:56 PM   #10
The problem is that for ceiling heat to radiate downward you have to really heat up the ceiling and I am sure that is just putting a heck of a whoppin on that paint.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
jsheridan (02-01-2013)
Cracking Paint in Bathroom RobynSN Painting 12 01-14-2013 04:35 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
