-   -   Paint cracking (http://www.diychatroom.com/f4/paint-cracking-170578/)
sylviamr 01-30-2013 03:29 PM
Paint cracking
i PAINTED MY HOUSE APPROXIMATELY 4 MONTHS AGO. I HAD TROUBLE BEFORE WITH THE PAINT FROM lOWE'S SO THIS TIME WENT TO sHERWIN WILLIAMS AND TOLD THEM OF PROBLEM THAT PAINT WAS CRACKING EVEN WITH NEW PAINT. i SANDED ALL THE WALLS. thE Y GAVE ME PAINT THEY SAID IT WOULDN'T HAPPEN ANYMORE. 4 MONTHS LATER IS HAPPENING AGAIN. cAN ANYONE GIVE ME ADVICE WITH THIS PROBLEM.
hOUSE HAS RADIANT CEILING HEAT.
THANKS
jsheridan 01-30-2013 03:58 PM
What walls are they, is the outside on the other side of them? Is it the top or bottom of the walls, or throughout? Has this been an issue for as long as you owned the house? Try to give a bit more info.
chrisn 01-30-2013 05:56 PM
Was there wallpaper before you painted?
Gymschu 01-30-2013 06:51 PM
Were walls prepped properly? Did you sand and remove dust from the walls before priming? You did prime with a quality drywall primer? Apply 2 coats? Millions of variables here and we need more info to help you. Adding a pic of the problem really helps also.
Nailbags 01-30-2013 10:53 PM
first off you have your cap lock on. second what did you do for prep work? what is the substarit you are painting? where is it cracking? on the taped seams? nail pops? what? a photo is worth so much to help us help you.
mt999999 01-31-2013 02:30 PM
If it is on exterior walls, could be too much moisture from the inside of the house. Same in vice-versa. I'd say to check for moisture problems.
Matthewt1970 01-31-2013 03:11 PM
THANKS
That might be the problem.
jsheridan 01-31-2013 03:45 PM
That's the first thing that crossed my mind Matt. I've seen it before firsthand and we just discussed it here a few weeks back. But, the problem is only ever with ceilings, not walls, that I've ever seen or heard. That's why I asked if it was the top of the walls, where it might be possible that the heat coming off the ceiling is affecting them.
joecaption 01-31-2013 04:41 PM
I bet the person that came up with RADIANT CEILING HEAT is the same person that came up with partical board, Masonite siding, quest tubing, Cellotex, and orangeberg pipe.
Heat rises, why put it in a ceiling?
Matthewt1970 02-01-2013 12:56 PM
The problem is that for ceiling heat to radiate downward you have to really heat up the ceiling and I am sure that is just putting a heck of a whoppin on that paint.
