Paint Coverage - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2007, 01:00 PM   #1
Paint Coverage
I recently made some drywall repairs or patched a few holes and applied "one" coat of BEHR Premium Plus "satin" finish paint. I noticed that you can actually see where I applied joint compound through the paint. Can someone tell me if I apply another coat will this clear up the imperfection?
Or should I apply possibly (KILZ) stain blocker first?
normanr is offline   Reply With Quote
Old 08-20-2007, 02:05 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
That's not surprising
You don't mention what type of repair you did, but most types of repairs require a coat of primer first, then two coats premium paint will usually cover it
-if- the repair is smooth...Paint colors, it doesn't fill
If it's not smooth, it may need a skim coat of joint compound over it
Then sand smooth, then primer, then two coats paint
If it's smooth now, you might want to consider a coat of primer, even though it has a coat of Behr on it already
Behr can take 3 - 5 coats to look good under the best of circumstances, I wouldn't bet that two more coats over un-primered would look OK
It doesn't have to be Original Kilz (oil-based) unless it's a deep/dark stain
Then it wouldn't be a bad idea
The latex Kilz (Kilz2 etc.) isn't very good, I'd recommend a Zinsser product if at all possible (BullsEye 1-2-3)...or Ben Moore or Sherwin Williams latex primer
Last edited by slickshift; 08-20-2007 at 04:54 PM. Reason: changed would to wouldn't...oops
slickshift is offline   Reply With Quote
Old 08-20-2007, 04:27 PM   #3
Thanks for the info
Old 08-20-2007, 04:55 PM   #4
slickshift's Avatar
You bet...anytime
Old 08-23-2007, 02:42 AM   #5
Pro Painter
It will be hard to touch up with the satin paint. Probably need to repaint the whole wall.
joewho is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 10:29 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
