Paint From Concrete Floor - Painting - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 11:43 AM   #1
paint from concrete floor
I am trying to remove paint from a concrete floor. I have tried a paint stripper and sanding it off. So far the sanding works best but I can't get the sand paper to stay on the sander. After a few minutes the sand paper will no longer stick. Any suggestions on how I can remove the paint from the floor? There is a lot of paint around the perimeter of the room where the walls had previously been spray painted when we bought out house.
jfreihaut is offline   Reply With Quote
Old 07-02-2011, 02:02 PM   #2
If there's enough of it, in all honesty, it would probably be easier to paint the floor than clean paint off of concrete. A pressure washer and a special concrete tip might work, but with that, Katie bar the door. Or, go to a real paint store and explain your situation, purchase some real chemicals. Today's off the shelf paint strippers are closer to after dinner cocktails than paint strippers. Disclaimer: Since we covered suing in the frog tape thread, I am in no way endorsing, or encouraging, paint stripper to be used as an after dinner cocktail, especially before 5:00 pm. lol (added for emphasis)
Old 07-02-2011, 04:08 PM   #3
Rewards Points: 1,016
What floor covering is planned to go down once the paint is removed? Is it really nessisary to remove the paint?
a power washer will likely take it right off but may be problematic for usage indoors
____________
Vince
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
Epoxy Paint on Previously Painted Concrete Floor goodkarma Painting 6 07-10-2008 01:04 PM
